Heater only blows on high.
Old October 14th, 2012, 04:28 AM
fritz442's Avatar
Hi folks, I know this topic has been beaten to death, but I have to ask. 72 Cutlass 350 w/AC, heater didn't blow at all. Replaced the relay by the brake booster and was getting a click. Found the inline fuse and replaced that, now I have high only. Whats next? Resistor? Is that another relay over by the blower motor, next to the big round emissions-looking thing. Thanks for any help!
fritz442 is offline
Old October 14th, 2012, 06:06 AM
Lansing built
1970cs's Avatar
Here is the link to a 1970 heat/ac diagnostic flow chart should be the same system. page 1-18 manual
Link is to wildaboutcars.com free to join and use!!!!
http://wildaboutcarsonline.com/membe..._Section_1.pdf
Pat
1970cs is offline
Old October 14th, 2012, 06:23 AM
Originally Posted by fritz442
Hi folks, I know this topic has been beaten to death...
Yup.
... heater didn't blow at all.
Found the inline fuse and replaced that...
So far so good - looks like you're doing the right stuff.
... now I have high only.
So the high position on the switch, the high-speed relay, the high-speed fuse, the general heater blower fuse, the blower motor, and all of the associated wiring and connections are good.
Yup, or the resistor plug, or wiring that goes to it, or the low-speed terminals of the switch, or the low-speed terminals of the relay.
Resistor's the most likely, though.
Is it connected?
It's easy enough to take it out and take a look at it.
Well, I'm not sure what round thing you're talking about, but in '72 some A/C cars had low-temperature relays, and some had rear defogger relays.
MDchanic is offline
Old October 14th, 2012, 07:45 AM
jaunty75's Avatar
This is the classic symptom of a failed blower motor resistor. Replacing that is your next step.
jaunty75 is offline
Old October 14th, 2012, 07:57 AM
fritz442's Avatar
Thanks guys, I think I'm getting close then. So where exactly is the resistor? Under the hood or dash?
fritz442 is offline
Old October 14th, 2012, 09:39 AM
jaunty75's Avatar
The 1972 Chassis Service Manual, available for free at wildaboutcars.com, shows the resistor to be mounted on the heater case up under the dash behind the glovebox. The manual says to disconnect the wiring harness from it and remove the two screws that hold it on.
If you do go look for the manual, it's figure Figure 1-27 on page 1-17.
jaunty75 is offline
Old October 14th, 2012, 10:02 AM
Rickman48's Avatar
Over the years, I've had this problem, and usually found the harness plug melted at the resistor. I was lucky enough to repair it to work.
Only once did I have to replace a burned-out assembly, and was lucky enough to find a used one.
Rickman48 is offline
Old October 14th, 2012, 10:10 AM
Sorry, Jaunty, not to bust your chops, but he's got A/C (or we wouldn't be having the "only works on High" discussion), and you're looking at the "heat-only" diagram.
On A/C cars it's right out in the open on the evaporator box, under the hood, as seen here:
Takes all of about 60 seconds to replace it.
MDchanic is offline
Old October 14th, 2012, 10:14 AM
I agree that that's a strong possibility, which is why I didn't pin myself down to the resistor being the only part of the circuit that could be bad.
If it's just the plug, the spade connectors can usually be removed from it individually and cleaned up, and if worse comes to worst, they can be replaced with ordinary ¼" spade females and used without the plastic plug assembly.
MDchanic is offline
Old October 14th, 2012, 02:08 PM
fritz442's Avatar
Thanks everyone! Got Patriots today, I'll check it out this week hopefully that'll do it!
Ed
fritz442 is offline
Octania
January 30th, 2016 09:18 PM
Octania
July 16th, 2015 09:53 AM
mhood
August 12th, 2011 10:18 AM
Flye
April 4th, 2009 05:29 AM
Gert3116
January 13th, 2008 11:48 AM
Quick Reply: Heater only blows on high.
