HELP: 67 cutlass dash lights and dash removal???
Old April 5th, 2014, 08:39 AM
mrnursedude's Avatar
hey all,
ive looked and looked before posting this so maybe some one can help.
first, i am trying my best to figure out how to take the dash out partly in my 67 cutlass supreme so that i can get to the dash lights that light up my speedo and the clock and possibly any other light that should be working. i have flipped upside down but my big hands and arms can not fit into the very small part under the dash.
i want to change them out and add new l.e.d. lights. plus the lights in there now don't seem to be working at night and i really wish that they work before i turn my teenager loose with it at night time.
if anyone can help with this, i would be in your debt. thanks...
mrnursedude is offline
Old April 5th, 2014, 09:35 AM
Member
halffast's Avatar
The factory assembly manual for this project and others is extremely helpful. It has exploded views of the entire instrument panel and all of the fasteners locations. Its a life saver. Readily available on line. Someone may be able to post a photo of the page you need. Mine is packed away.
halffast is offline
Old April 5th, 2014, 11:33 AM
thanks mark. yes, i have looked for a manual on line but have come up empty. i thought someone out there might have it posted but no luck for me yet.
i do like your thought of someone maybe posting a few pictures of this manual from their books if i could just find someone to do this.
thanks for your help and your reply.
p.s. i like the icon picture you have up. is this your 66?
Old April 5th, 2014, 11:50 AM
jaunty75's Avatar
You haven't looked hard enough.
Go to wildaboutcars.com, join up (it's free), and get the complete '67 Olds Factory Service Manual there plus a lot of other stuff. Removal of the Cutlass instrument panel is covered in the Electrical section beginning on page 12AA-1.
jaunty75 is online now
Old April 5th, 2014, 12:17 PM
Member
halffast's Avatar
Yes that's my 66. Finished the resto a few years ago, but you know how that goes... you're never really finished. Always something to do or redo. I do love it though.
halffast is offline
Old April 5th, 2014, 01:32 PM
tecar442's Avatar
2X on the online assembly manual. I find that a hard copy is much easier to use, though. You need to own one. In order to get the dash out you need to remove the seats, steering wheel, radio, glove box, cables, and more to easily access the nuts that hold your dash and dash pad in place. Not really difficult, you can do it. Assembly manual shows all parts. Have fun.
tecar442 is offline
Old April 5th, 2014, 02:51 PM
thanks a lot for your help.
yes i have looked and looked jaunty75 but i guess i was just researching wrong words. thanks again.
thanks also tecar442. sounds like a chore to do. all i want is to change the light bulb. hope i don't have to go too far in depth because this is really my daily driver.
looks really good halffast! i'd love to see before and after pics if you have them.
Old April 7th, 2014, 07:44 AM
67442nut's Avatar
.....all i want is to change the light bulb. hope i don't have to go too far in depth because this is really my daily driver........
I've owned '66 & '67 Cutlasses and 4-4-2's for 45 years and have changed lots of dash lights.
I've never had to remove the dash to do so.
If you have a factory A/C car, you may need to remove some of the ductwork under the dash,
but, this is much easier than removing the dash.
Just a few screws and the ducts are out of your way.
I've removed several dashes over the years.
If you decide to do so, I'll be glad to tell you what I know.
I have a factory manual if you need hard copies on the dash removal.
67442nut is offline
Old April 7th, 2014, 09:35 AM
Octania's Avatar
I've owned '66 & '67 Cutlasses and 4-4-2's for 45 years and have changed lots of dash lights. I've never had to remove the dash to do so. If you have a factory A/C car, you may need to remove some of the ductwork under the dash, but, this is much easier than removing the dash.
Agreed.
Reach up in there and twist and remove the illuminators.
Octania is offline
Old April 7th, 2014, 09:40 AM
Run to Rund's Avatar
x3. But if you insist on removing the instrument panel and pad, get a deepwell 11/32" socket.
Run to Rund is offline
Old April 7th, 2014, 10:18 AM
Chesrown 67 OAI's Avatar
Get a boy or girl with small hands to get up in there for you. My wife can get her hand up in there easily.
Chesrown 67 OAI is offline
Old April 11th, 2014, 01:33 PM
thanks for all of your help. have been sick so has taken me a while to respond.
i guess i should have been more specific in my words but yes, all i want to do is to pull the lights out from the dash and replace them with l.e.d.'s to illuminate better.
i'd like to do the least amount of work as it is to get this done. pulling the dash is the LAST thing i want to do. i just don't have the knowledge to do what i need to do. this is where the help part comes in.
i have laid on my back upside down under the dash and i know there is not physical way i know of removing the lights in dash. i dont see them plus my hands resemble bigfoots hands.
if someone could tell me what im looking for that would work out great. i have an automatic and it does have factory air.
Old April 11th, 2014, 04:45 PM
rroth01's Avatar
Location: Orion Township Michigan 30 Miles North of the Murder City
Send me an Email to rroth01@att.net I have a spreadsheet to get you out.
Ron Roth
586-556-1234
rroth01 is offline
Old April 11th, 2014, 04:49 PM
rroth01's Avatar
Mr Nurse Dude
I have read where LED's have a Polarity to them.
You may just be 180 degrees off.
Ron Roth
Navy Seal
rroth01 is offline
Old April 11th, 2014, 10:55 PM
thanks @rroth01. just sent out email to you.
Old April 12th, 2014, 07:49 AM
rroth01's Avatar
David I just sent you the Spreadsheet.
rroth01 is offline
Old May 7th, 2014, 06:48 PM
69cutlassman's Avatar
rroth01
If that spreadsheet works for a 69 convertible and help me changing some of the bulbs around the dash, I would be very interested in seeing it.
69cutlassman is offline
Old November 12th, 2019, 03:27 AM
Hondo's Avatar
Wink Ron,
Ron Roth
586-556-1234
Ron, I know you wrote this years ago, but I'm also replacing all the dash lights. would love to havea copy of your spread sheet.. if you still have it.
thank you in advance
Hondo is offline
scooter123
September 28th, 2013 07:32 PM
devmar07
February 23rd, 2012 04:40 PM
oldstuff
September 13th, 2011 08:03 AM
Sid
September 10th, 2010 02:33 AM
Bryan59EC
June 3rd, 2010 10:36 AM
Quick Reply: HELP: 67 cutlass dash lights and dash removal???
