Horn contact
Old March 16th, 2024, 09:30 AM
Pug Wrangler's Avatar
Horn contact
I gave up on fixing my horn almost 2 years ago to move on with other issues. I have a 72 Cutlass with an aftermarket sport wheel. It seems like I needed a longer contact pin, is this correct and does anyone have a part number?
Pug Wrangler is offline
Old March 16th, 2024, 02:01 PM
4speed455's Avatar
You need Dorman 83230 or equivalent. Same parts used on Corvette so readily available for $7-10. And the horn contact ring. I don’t have a part number for that one but here is one on eBay for $27.50 https://www.ebay.com/itm/12414932375...Bk9SR6rs_ZDJYw
4speed455 is online now
Old March 16th, 2024, 02:06 PM
I didn't know I had to change the ring also, thank you.
Old March 16th, 2024, 02:10 PM
4speed455's Avatar
Your welcome. Also on the Dorman kit, the spring goes in the hole first, then the pin with the wider spot first, finally the plastic collar slides over the pin and locks it into place.
Old March 16th, 2024, 02:40 PM
Which "ring"? The cancel cam?
joe_padavano is offline
Old March 16th, 2024, 03:59 PM
It says horn contact
Old March 16th, 2024, 04:08 PM
Again, are you talking about the small black ring that holds the HORN CONTACT in the tube on the cancel cam, or the HORN CONTACT ring that is part of the cancel cam itself?
Old March 16th, 2024, 04:17 PM
The small ring comes with the contact kit. 4speed says I also need the contact ring also. I don't know if I do or not.
Old March 16th, 2024, 04:20 PM
If by contact ring you mean the spring-loaded ring that the horn cap snaps into, you can't mount the horn cap without it.
Old March 16th, 2024, 04:24 PM
I have one, he says I need a different one.
Old March 16th, 2024, 04:26 PM
They all look exactly like the one in the photo above.
Old March 16th, 2024, 04:34 PM
Okay then. Thank you for clearing that up for me Joe
Old March 16th, 2024, 11:13 PM
4speed455's Avatar
Sorry I didn’t mean to cause any confusion, I was just showing the correct parts to make your horn work.
Old March 17th, 2024, 08:04 AM
No worries, I misunderstood.
Old March 23rd, 2024, 09:43 AM
Is this right? The wide end of the pin doesn'
t want to fit into the sleeve
Old March 23rd, 2024, 09:54 AM
Yes that is correct.
Old March 23rd, 2024, 10:08 AM
thank you Joe
Old March 23rd, 2024, 12:58 PM
I'm so close! one more question. Do the tabs on the contact ring go above or below the steering wheel? If I put them on top the horn doesn't sound, if I put them below I can't get the cap on.
Old March 23rd, 2024, 03:18 PM
70Post's Avatar
Horn contact ring goes on AFTER the steering wheel is installed on to the hub. Sometimes there isn't enough "travel" allowed for the horn contact ring "springy" part to contact whatever it contacts to make the horns honk. You could try three small flat washers b/n the horn contact ring tabs (one under each tab) and the steering wheel face.....see if that gets the horn to work.
70Post is offline
Old March 23rd, 2024, 05:00 PM
That might work, thanks!
Old March 24th, 2024, 09:00 AM
That did it! I had to grind the washers way down so they didn't make contact with the inner part of the ring, o-rings probably would have worked better.
Thanks for all the help guys!
Huero59
December 1st, 2023 04:32 AM
sjay1989
February 5th, 2020 04:16 PM
88hurstolds
January 18th, 2016 09:18 AM
DennisG.
April 15th, 2012 11:01 AM
orange442
May 14th, 2006 03:06 PM
Quick Reply: Horn contact
