horn relay drains battery
Old November 21st, 2012, 08:08 AM
TalksToToads
CrazedCountryRebel's Avatar
Hi, the horn relay in my 68 Delta 88 is draining the battery, As soon as I disconnect the wire that goes to the battery it stops draining, but then the car won't start. I looked at the manual and it is hooked up correctly so I replaced it, but it is still draining. My plan is to run the wire to a switched source so it only has power when the key is on, but I'm afraid it is fairly high amp draw and will just blow whatever fuse I hook it to. Is there an easy way to hook it to the ignition switch without going to the fusebox? Like maybe something under the hood? Otherwise how can I find out what is causing it to drain? Thanks.
CrazedCountryRebel is offline
Old November 21st, 2012, 08:15 AM
Lady72nRob71's Avatar
So does the horn itself work right?
If so, then the horn relay is not the problem.
That big stud just serves as a junction block to distribute power. Next step would be to put a current meter inline with the battery - and the - cable and see what you read. Key stays OFF during this test. Then start pulling fuses one by one until the current draw goes away. You might disconnect the regulator and alternator before the fuses to see if the issue is there.
Lady72nRob71 is offline
Old November 21st, 2012, 08:33 AM
TalksToToads
Yes the horn works, I will check the fuses.
Old November 21st, 2012, 10:49 AM
TalksToToads
I pulled all of the fuses and none of them stopped it. When I unplug the little plug in the back of the alternator, the drain stops.
Old November 21st, 2012, 12:56 PM
Seff's Avatar
I had a similar problem with my internally regulated alternator, turned out to be a screw that wasn't isolated from the alternator casing properly.
Seff is offline
Old November 21st, 2012, 05:48 PM
So is your alt the original type with ext reg or something aftermarket?
Old November 21st, 2012, 06:43 PM
Is the problem the horn relay or the alternator? I'm confused.
MDchanic is offline
Old November 21st, 2012, 07:17 PM
TalksToToads
It is the original type. I just remembered that it does not have a ground wire on it, I wonder if that is causing it, I will have to check that out tomorrow.
Old November 21st, 2012, 07:55 PM
The alt does not have a ground wire - it grounds through the case.
It is possible one of the diodes inside the alt have turned leaky. They can replaced after the alt is opened up. With key off, and plug plugged in, measure from the white wire to ground with a volt meter. If you get something, the diodes leak.
Old November 21st, 2012, 07:56 PM
The horn relay does not have a ground wire. It grounds to the body.
In a '68, if I recall, there is no ignition key buzzer, so the relay has four terminals.
One is the ground.
One is the hot post to the battery.
One is the wire from the relay to the horn button, which is grounded when you blow the horn.
One is the wire to the horns.
That's it.
Press horn button —> ground horn button wire —> current flows from battery post through relay coil to ground, pulling contacts in and connecting battery post to wire to horns —> horns blow.
That's all there is.
No rocket science or magic.
MDchanic is offline
Old November 21st, 2012, 08:07 PM
He found the issue was with the alt.
Old November 21st, 2012, 08:25 PM
Okay, I've got it now.
He replaced his horn relay because disconnecting the alternator (the wire to the battery) from the horn relay stopped the battery from draining.
Kind of like replacing the fuel pump because you've got a bad float needle.
Why do people replace parts first and troubleshoot later?
I think I'm in a bad mood.
MDchanic is offline
Old November 27th, 2012, 10:01 PM
Orlando Perez's Avatar
So the horn relay has needs to have two red wires one to the batterry and the other to the Alternator?? Im havin the same problem
Orlando Perez is offline
Old November 28th, 2012, 07:39 AM
Hey! I'M supposed to be the cranky curmudgeon on this site!
joe_padavano is online now
Old November 28th, 2012, 08:40 AM
Depends on the car and year.
On the horn relay in 72 -
One to the ALT, one to the regulator, one to the starter solenoid (where the + batt cable connects), one to the fuse box inside, one to the AC blower relay and one to the rear defroster (if you have it).
Two's of them's a crowd......
Old November 28th, 2012, 06:49 PM
Always room for more cranky old goats!
matt69olds is offline
Old November 28th, 2012, 07:03 PM
I defer to your crankiness, Joe, as it is made of sterner stuff than mine.
MDchanic is offline
Old December 14th, 2012, 08:20 AM
TalksToToads
I will have to try that, I haven't gotten a chance yet because now I have much worse problems... https://classicoldsmobile.com/forums...tml#post485717
pcard
May 14th, 2014 01:21 PM
59Olds98
December 25th, 2013 08:20 AM
defiant1
May 31st, 2011 04:30 PM
ctrain22
September 16th, 2009 05:27 AM
bradsgarage
May 13th, 2009 11:17 AM
Quick Reply: horn relay drains battery
