Idiot light for alternator output.
Old June 17th, 2012, 05:12 PM
bobfo1's Avatar
I have a 66 442 that was converted to an internal regulator alternator. I have s/w guages to read the real output for temp, pressure and alternator charging, but at the same time I am using the idiot lights. The problem that I am having is that with the engine running, and the voltmeter showing proper charging, the charging idiot light glows...not brightly, but some. Is this a common result when an internal regulator alternator is used in this circuit?
bobfo1 is offline
Old June 17th, 2012, 08:47 PM
2blu442's Avatar
Sorry I don't know the answer, but back to the top!
2blu442 is offline
Old June 17th, 2012, 08:58 PM
Just the facts...
BILL DEMMER's Avatar
need a little more info...
what alternator are you running? 10si, 12si, cs-series? i assume you came from a 10dn alternator. what is your charging voltage? where did you connect the sense line?(thinner red wire)
bill
BILL DEMMER is offline
Old June 18th, 2012, 10:00 AM
stellar's Avatar
Need more info, but if your alt has a diode trio, 10 or 12 or 15 or17SI type, it may have a defective diode in the trio and still charge with the lite showing dim like yours does.
stellar is offline
Old June 18th, 2012, 10:06 AM
It's a very common problem when the conversion to internal regulator is not done properly.
joe_padavano is offline
Old June 18th, 2012, 04:37 PM
bobfo1's Avatar
The alternator that I have on the car is (I think) a 10si, 55 amp. The car is down right now for some other work, but the charging showed 12-14 volts. There is no thin red wire going to the alternator...large red, white, and blue only. The wires going to the external regulator are not used....one of those wires is small guage red...the wires that connected to the external regulator are "capped" as part of the change to the internal regulator alternator.
bobfo1 is offline
cfair
April 29th, 2014 09:19 AM
travisbeamon
March 5th, 2013 10:47 AM
yeahbuddy
March 6th, 2012 04:22 AM
EastLansing
December 6th, 2011 07:18 AM
Gaz Hog
May 11th, 2008 02:47 PM
Quick Reply: Idiot light for alternator output.
