Internal vs external regulation
Old September 30th, 2014, 06:25 PM
Dbechtel71's Avatar
Hello what is the difference between external and internal regulation? I guess the real question is when figuring out which wire harness I want to use I noticed that one has the wires that go to the voltage regulator on the wall and my other does not have the wires. If I use the one without the wires to the wall regulator do I need an internally regulated alternator? Hope I didn't confuse anyone
Dbechtel71 is offline
Old October 1st, 2014, 02:56 AM
Lansing built
1970cs's Avatar
I had to go back in your history to see what we were working on! 1970 Cutlass S. Factory would be wires headed back to the firewall to the external regulator.
I guess the next question would be which style alternator do you have and which way you do want to go?
Pat
1970cs is offline
Old October 1st, 2014, 06:04 AM
The left alternator is an internal the right is an external. The difference looking at them is the position of the pins on the 2 pin connector.
oldcutlass is offline
Old October 1st, 2014, 06:17 AM
Beer Connoisseur
70cutty's Avatar
The difference is that externally regulated alternator requires a voltage regulator and internal doesn't.
70cutty is offline
Old October 1st, 2014, 07:31 AM
garys 68&72's Avatar
Before swapping over to internal regulator with a plug and play "kit", read this post.
I ran across the EXACT same issue over at one of the corvette boards.
Either will work if wired correctly.
https://classicoldsmobile.com/forums...rcharging.html
garys 68&72 is offline
Old October 1st, 2014, 01:29 PM
Originally Posted by 70cutty
The difference is that externally regulated alternator requires an EXTERNAL voltage regulator and internal doesn't.
I made a clarification to your post.
Fun71 is online now
Old October 1st, 2014, 01:37 PM
Beer Connoisseur
70cutty's Avatar
Thanks.
70cutty is offline
Old October 3rd, 2014, 05:13 AM
Dbechtel71's Avatar
Thanks I figured it out
Sampson
January 9th, 2014 12:12 PM
jims2000lt
November 22nd, 2012 08:22 PM
danlonchar
October 2nd, 2010 12:34 PM
1970_442
July 8th, 2010 03:30 PM
redvettemike
May 26th, 2009 01:09 AM
Quick Reply: Internal vs external regulation
