No high speed blower motor
Old December 13th, 2011, 03:40 AM
ao177snipe's Avatar
I have a 1973 olds 88 royal cpe with A/C and a 350 I have all of the blower motor speeds but HIGH, I am new to the older cars and am in need of advice on where to start, I have check the fuse box underneath the dash and all of the fuses are good, any starting point will be greatly appreciated. Steve
ao177snipe is offline
Old December 13th, 2011, 04:17 AM
Inline 30A fuse along the firewall (engine side) between the horn relay and the fan high-speed relay, which is on the fiberglass evaporator housing.
If not the fuse, then one of the contacts in that line, the relay plug, or the relay itself.
MDchanic is offline
Old January 30th, 2012, 03:04 PM
leeburch1's Avatar
I have a '65 with simular problem. Found the problem was a faulty blower switch. Hope you have better luck than I finding a replacement
leeburch1 is offline
Old January 30th, 2012, 03:33 PM
You can often disassemble and clean the blower switch - just be sure to keep track of the direction that ALL the parts fit together!
MDchanic is offline
Old January 30th, 2012, 03:40 PM
leeburch1's Avatar
Hey thanks; might be my best option.
mmurphy77
June 17th, 2014 12:49 PM
johnnyhawthorn
March 12th, 2014 05:10 PM
willys33
June 28th, 2013 09:00 PM
Magna86
February 14th, 2013 07:16 PM
krashx7
December 19th, 2012 01:43 PM
Quick Reply: No high speed blower motor
