One speed heater motor
Old February 12th, 2022, 07:24 AM
Dave’s Holiday 55's Avatar
My 1955 Super 88 has a three position heater fan switch; high, low, and off. The fan motor has only two wires, one is a ground, the other is power. The fan runs on low speed in both the low and high positions. Off works. I read somewhere that a resistor or some other electric gadget is responsible for changing the speeds. Where is that gadget? In the switch? In the heater box on the engine side of the firewall? Somewhere else? It’s starting to get cold here in Kansas and I’d like a little more control of the heater. The heater does put out warm air and the fan motor is new. Ideas? Solutions?
Dave’s Holiday 55 is offline
Old February 12th, 2022, 08:00 AM
The blower motor speed control resistor is mounted in the heater box and looks like this. This thread has a series of good photos.
joe_padavano is offline
Old February 12th, 2022, 08:13 AM
That’s just what I needed to see. As soon as I get a warmer day, and finish the wife’s honey do’s, I’ll crawl under there and see what I can find. The pictures should help. Thank you.
Old February 12th, 2022, 09:30 AM
Note that there are actually three unique motor speeds, LOW, HIGH, and DEFROST. Both heater speeds go through the resistor. The defrost switch bypasses the resistor and runs full power to the motor. If the defroster switch is stuck on, you will only get full speed no matter what setting the switch is on. (yeah, this is a 1956 wiring diagram - the 1955 heater works the same way)
Old February 13th, 2022, 11:11 AM
Thank you. I’ll check the defroster.
Old February 13th, 2022, 02:32 PM
Frank Ignachuck
ignachuck's Avatar
Also, check the connections. As I mentioned in the thread that Joe referenced above. I got my '56 to work by just cleaning the contacts.
ignachuck is offline
Dave’s Holiday 55
November 12th, 2021 08:32 AM
JVCCutlass
November 4th, 2021 08:23 AM
Bennettre46
March 11th, 2016 05:36 PM
ignachuck
February 23rd, 2016 04:36 PM
Erinyes
May 5th, 2012 08:06 AM
Quick Reply: One speed heater motor
