Picture of am/fm Radio?
Old August 16th, 2013, 04:08 PM
Demonator666's Avatar
Greetings. Anyone have pics of factory am/fm Olds Radios, specifically the front face of 70-72 models? Thanks!
Demonator666 is offline
Old August 16th, 2013, 05:29 PM
bsambo59's Avatar
Here are a couple shots of mine out of my 70' Cutlass. Factory 8 track being restored and coming soon!
bsambo59 is offline
Old August 16th, 2013, 05:35 PM
bsambo59's Avatar
I can get much clearer and detailed pics this weekend if you need them.
bsambo59 is offline
Old August 16th, 2013, 05:42 PM
Al Sanchez's Avatar
1972 Cutlass supreme... Am/fm radio
Al Sanchez is offline
Old August 16th, 2013, 05:53 PM
Thanks. I'm trying to figure out what ***** are behind the main ***** (volume/tuner). I bought a radio and it appears the secondary ***** and the am/fm toggle switch are not correct. Yes, if you can send a clearer pic of them I would appreciate it.
Bruce
Old August 16th, 2013, 06:04 PM
Left side is Volume/bass/treble, Right side is Fade front/rear (or nothing if your radio isn't equipped for rear speake)
There are also little 'wave' washers that go between the main ***** and bottom controls. Most radios are missing these, but you can pick them up cheap at places like Home Depot or parts supply. They look like these (not to scale - just for image)
Allan R is offline
Old August 16th, 2013, 06:09 PM
Al Sanchez's Avatar
On mine, the left says.. Music,Bass,Voice and on the right it says... Speaker,Front,Rear. Three words on each one
Old August 16th, 2013, 06:15 PM
Just saw your pics, Al. Do the "Music" and the "Speakers" plates move? If not, do you push the front ***** in to adjust or is there secondary ***** between the front ***** and the rear plates?
Old August 16th, 2013, 06:32 PM
Al Sanchez's Avatar
Yes the ones in the back do move, but they do not spin they have a stop, in other words is like they have three settings, if it's in the middle you can turn it left and it stops and if you turn it right it will stop on that setting.. And the small ***** are volume left and station tuner on the right.. Can you post a picture of your radio
Old August 16th, 2013, 07:48 PM
I'll post a pic of my radio when I get home. I can tell you now the ***** in back are not like the ones I've seen on this thread. Everything else seems correct. Thanks guys.
Old August 17th, 2013, 08:46 PM
This is the radio I bought. Notice the secondary ***** behind the front *****.
Old August 18th, 2013, 09:40 AM
Al Sanchez's Avatar
The large **** on the right looks correct for that radio but it should go on the left side and the small one on the left side ofcours it's not correct it's probably doing the jod, I'm sure multiple ***** will fit this radio but if you're looking for originality you just need to find that one that is missing and like Allan said it comes down to your radio if it has the front and rear speaker option, have you tried to power up the radio ? Did you get any sound
Old August 18th, 2013, 02:18 PM
Thanks. The info and pics you guys attached have really helped me out! I'm going to contact the guy I bought it from to see if he has the larger ****. He has several radios and will probably help me out. I'm going for the original stock look. I haven't tried to get sound from it yet. My car has the factory 8-track player so hopefully I can get both hooked up and working so I can enjoy crappy sound.
Bruce
Old August 21st, 2013, 06:24 PM
Awww, the sound isn't all that crappy especially if you have the AM/FM Stereo option. Just the AM will sound tinny. With that radio you MUST run 10 ohm speakers. The front one is already in the dash and is the same with all the Cutlass line. The rear is a 6x9.
Want a really good way to clean those *****?? Seriously I found this out by accident. I left on in my coveralls and washed them. The soapy water and gentle scrub of the fabric made it gleam like new. It will NOT take off pitting, but if you have just accumulated grime? Put them in an old sock, fold it back on itself so it can't fall out and throw them in the wash.
Allan R is offline
dnmfranco
July 2nd, 2014 05:10 PM
dancutlass
October 2nd, 2012 02:49 AM
sx455raidercelticfan
July 29th, 2010 07:44 PM
denis
January 17th, 2007 10:14 AM
<miltoncutlas@aol.com>
January 31st, 2004 12:20 AM
Quick Reply: Picture of am/fm Radio?
