Radio keeps shorting out
Old March 19th, 2008, 09:43 AM
Familio's Avatar
I have a 1966 Delta 88 convertible. I installed a JVC dvd/cd receiver and everytime I push on the brake, it shuts the receiver off. The receiver comes back on most of the time, but sometimes it doesnt until a week or two later. It works fine until I push the brake. Can anyone help me?
Familio is offline
Old March 19th, 2008, 10:44 AM
Past Administrator
Oldsguy's Avatar
You need to verify that your charging system is good; battery, cables and alternator. Rusty or corroded brake lamp sockets, bad wiring, or loose contacts in the fuse block itself could be loading down the 12volt source and if the charging system is not up to speed then the voltage drops. Normally, old wiring doesn't cause this kind of problem. After you correct your charging system problem then you can check the sockets and wiring in the brake lamp system and fix them up if needed. finally, I assumed you wired the unit according to the instructions so I didn't address that but a nice clean installation that is fused correctly shouldn't cause any trouble.
Oldsguy is offline
Oldscutty72
December 28th, 2015 01:56 PM
joealexander1234
22
October 14th, 2010 09:13 AM
jaunty75
February 7th, 2010 04:30 PM
Hydro462
January 16th, 2010 08:38 PM
57teebyrd
December 21st, 2006 07:07 AM
Quick Reply: Radio keeps shorting out
