ralley pac wiring pic's
Anyone have a pic's of the 1969 442 ralley pac wiring that has I think 7 wire's in it, plug's to the oil and temp gauge picture only from back of the gauge pluged in
http://72.22.90.30/phpBB2/viewtopic....ghlight=rallye
Jim
Look on the top of page 15-32 of the 69 CSM pdf I'm attaching. It shows which pins to what. http://wildaboutcarsonline.com/membe...ection_15B.pdf
Here is a picture that I have. The harness is the same for '68 and '69 with regards to what plugs into the gauges. Another thing that should be done in converting idiot lights to gauges is that the "check circuit" wire be disconnected so you don't ruin your new temp gauge.
On a '69, the "check circuit" wire is green, comes down the steering column from the ignition switch with several other wires, and plugs into a harness under the dash. All you have to do is extract that green wire out of the harness and tape it off to disable the "check circuit".
With idiot lights, when you turn the key on, the temp light also comes on. After the car is started, the temp light goes off. If you convert to gauges without disconnecting the "check circuit" wire, when you put your key in the "on" position, your temp gauge needle will peg. Once you start the car, the temp needle will go back to normal operation. Peg that temp needle too many times and it will eventually ruin your temp gauge.
Randy C.
Randy C.
69442murph
March 12th, 2013 03:03 PM
