so whats the trick to get to the Cigar and radio
Old July 6th, 2014, 11:48 AM
davoaz's Avatar
on a 72 Cutlass Supreme? Neither work. I've gone through the CSM and Assembly manual and all it shows is how they go together. Not what/where to start taking the dash apart to get to either one. It's impossible to reach up from underneath to get to either.
davoaz is offline
Old July 6th, 2014, 11:52 AM
Mr Shifty Sidney's Avatar
The CSM has an electrical diagram. That is where I would start.
Don W
Mr Shifty Sidney is online now
Old July 6th, 2014, 12:14 PM
davoaz's Avatar
Ya, the Fig12AA-9 shows how it goes together if I had the entire front panel sitting in my lap. There is no easy way to reach and pull retainer off. All I can think of remove entire instrument cluster so I can get my hand back there.
davoaz is offline
Old July 7th, 2014, 02:04 AM
Yellowstatue's Avatar
If you have A/C then you need to remove the ductwork. Then unplug the radio connections and remove nut from plastic strap on rear of radio, and then pull off radio *****, then using 5/8 deep socket (by hand usually) remove nuts on radio shafts and then catch radio as it falls towards floor... the cigar lighter can now be accessed through the radio cavity.
Yellowstatue is offline
sqeeek
February 26th, 2014 07:25 PM
olds70supreme
April 18th, 2013 02:47 AM
1970holidaycoupe
March 6th, 2013 06:26 PM
matt68
September 25th, 2009 01:43 PM
Barneyo
February 8th, 2008 05:18 AM
Quick Reply: so whats the trick to get to the Cigar and radio
