Starter wiring
Old May 11th, 2008, 12:36 PM
1FSTLS1's Avatar
Starter wiring
I am hooking up my starter on my 455 olds block in a 81 Trans Am. Can any one corect me if I am wrong. Small wire from sylonoid to ground. Ther wire (S) from sylonoid to +12 when key is cranked. Larger wire from starter to +batt terminal.
1FSTLS1 is offline
Old May 11th, 2008, 02:21 PM
Past Administrator
Oldsguy's Avatar
The small wire should go through the transmission switch (Neutral safety) before going to ground.
Oldsguy is offline
Old May 11th, 2008, 03:39 PM
1FSTLS1's Avatar
Got ya. Thanks I think I will bypass that.
1FSTLS1 is offline
Delta88royal
June 11th, 2011 10:53 AM
1973olds98
September 8th, 2010 07:15 PM
venividivici53
October 15th, 2009 10:09 AM
kingkong8808
September 10th, 2009 04:00 PM
mcutlass1969
June 23rd, 2007 08:49 PM
Quick Reply: Starter wiring
