TH400 Kickdown switch wiring
Old August 6th, 2012, 03:19 AM
Pryora's Avatar
Hello all,
I've recently changed my transmission from a TH200 to a TH400. I'm running into all types of trouble getting the thing hooked up as my Wiring harness has been cut and spliced more times than Micheal Jacksons nose. I purchased the kickdown switch but don't have the bracket that attaches it to my gas peddle. Nor do I know which wires to route to the transmission. I thought that all the dash harnesses were the same and only had to find the proper wire tucked away but I have come up empty. I thought about getting the TCI kickdown switch but yet again don't know how to wire it up.
Does anyone know how to aquire the kickdown bracket for the gas peddle. any help would be apprectiated thanks. -Arnee
Pryora is offline
Old August 6th, 2012, 05:59 AM
The kickdown at the trans requires a switched 12v signal at WOT. Basically fab a brkt that allows the switch to close when your pedal is floored and your there, very simple!
oldcutlass is online now
mmurphy77
July 2nd, 2014 12:03 PM
Uncle Hulka
April 23rd, 2014 05:00 AM
Olds luvr
February 26th, 2014 05:29 PM
AZ455
November 27th, 2011 08:35 AM
J-(Chicago)
November 27th, 2011 06:25 AM
Quick Reply: TH400 Kickdown switch wiring
