TH400 Kickdown switch plug needed
Old April 21st, 2014, 09:57 AM
Ancient Olds Lover
Uncle Hulka's Avatar
I'm converting from a TH350 to a TH400 and I am in need of the plug, boot and as much of the wire as possible, that goes onto the transmission kick-down solenoid.
If anyone can help me out I would appreciate it. If they're in CT, I can pick up.
Thanks very much!
Uncle Hulka
Uncle Hulka is offline
Old April 21st, 2014, 11:51 AM
delete
droptopron's Avatar
I assume its for the full sizer pictured. In an A body its part of the harness but not used. Maybe your's is the same way?
droptopron is offline
Old April 21st, 2014, 12:53 PM
Ancient Olds Lover
Sorry, I should have offered more details in my request.
The trans is out of a '69 Delta and is going into a '69 Cutlass. As outlined in the 1969 PIM, I found the connector that plugs onto the kick-down switch taped back onto its harness. The PIM says that if the car in question was made with a TH350, the connector that would normally be used to plug onto the TH400's kick-down solenoid is to be cut off. Evidently whoever's job it was to cut that connector off, cut the entire wire off right at the backside of the fuse panel on the firewall!
Long story short, I am in need of the connector plug, its boot and as much of its wire lead as possible.
Old April 21st, 2014, 01:22 PM
Beer Connoisseur
70cutty's Avatar
There is this one on Ebay
http://www.ebay.com/itm/68-69-TH400-...891d26&vxp=mtr
70cutty is offline
Old April 21st, 2014, 05:45 PM
Ancient Olds Lover
Hmmnnn.....didn't realize they made a repo harness. A used one would have been fine, but this looks like a great solution.
Many thanks!
Old April 23rd, 2014, 04:34 AM
Ancient Olds Lover
Originally Posted by 70cutty
Thought you should know that I think your suggestion will be my solution. I pulled the trigger and bought that harness. I'll let you know how that works out.
Thanks very much for your suggestion and link. I appreciate it more than you might think!
Old April 23rd, 2014, 05:00 AM
Beer Connoisseur
70cutty's Avatar
Glad I could help. I hope it works for you.
70cutty is offline
The Bug Man
March 27th, 2015 01:59 PM
mmurphy77
July 2nd, 2014 12:03 PM
Olds luvr
February 26th, 2014 05:29 PM
Pryora
August 6th, 2012 05:59 AM
AZ455
November 27th, 2011 08:35 AM
Quick Reply: TH400 Kickdown switch plug needed
