Upgrading alternator
Old December 28th, 2010, 07:27 AM
71KUTLASS's Avatar
Upgrading my 1972 olds cutlass alt with a 140 amp chrome right stuff alternator from summit racing. The new alt is a single wire but the one in the car now is not. has anyone done this before? if so any tips? Thanks!
71KUTLASS is offline
Old December 28th, 2010, 07:43 AM
Land Yacht Captain
66ninetyeightls's Avatar
Just do a search there are many threads on this subject.
66ninetyeightls is offline
Old December 28th, 2010, 08:16 AM
Run to Rund's Avatar
Is the alternator made by East Coast http://ecae.com/
The drag racers like that brand, lots of output and light weight.
Also check Powermaster's web site for help:
http://www.powermastermotorsports.com/tech_help.html
and the yellow bullet electrical section for threads; at the top are sticky threads with wire gauge recommendations vs. amps and length.
http://www.yellowbullet.com/forum/forumdisplay.php?f=29
Run to Rund is offline
Old December 30th, 2010, 05:05 PM
71KUTLASS's Avatar
HeLPPPPPPPPPP!!!!
Picked up a new alternator and now i cant get it to fit into the existing top mounting bracket. tried prying it back a little, then the bolt would not slide in properly. im looking for a good replacement. Chrome would be great. Anybody know where I can find one. I've searched ebay, summit racing and year one. Thanks
Old December 31st, 2010, 11:33 AM
stellar's Avatar
What are your electrical requirements? The cs144 is an excellent unit, but if it can't fit you may try a cs130. It also comes in a 1 wire if needed and will be a direct fit.
stellar is offline
Old January 4th, 2011, 07:30 PM
Aceshigh's Avatar
Yes,
3 wire is far better then a 1 wire in a street car for charging.
http://www.madelectrical.com/electri...hreewire.shtml
You have to make sure the alternator you're buying has the correct size and clock position to work. I got my 140amp CS130 off a guy on Ebay 2 years ago for ~$140. He custom makes them for your application. Internally regulated obviously, so some wiring modifications are necessary if your current one isn't. You can still see my external regulator on the firewall that I didn't remove yet when this pic was taken.
I measured bolt hole to bolt hole, and gave him the clock position. 3 wire, and fit perfectly.
I have the notorious Taurus 4500cfm electric fan, and @ idle I need the most juice I can get.
Plus I have a couple amplifiers in my trunk for my aftermarket stereo system.
If you have more questions, just PM me. I might miss them.
Aceshigh is offline
soundhd
Brakes/Hydraulic Systems
August 6th, 2012 11:18 AM
67 Olds 442
Suspension & Handling
April 3rd, 2012 06:38 AM
yankees
November 23rd, 2011 01:50 PM
67 Delta 88 hardtop
July 21st, 2010 12:49 PM
Moe
June 10th, 2010 07:04 AM
Quick Reply: Upgrading alternator
