Wiper switch for 62 98
Old April 23rd, 2024, 04:13 AM
Mikeyt
Mikeyt's Avatar
Wipers aren't working and switch doesn't seem to click on any setting.
Is there a source for new or does anyone rebuild them?
Mikeyt is offline
Old April 23rd, 2024, 06:04 AM
The correct switch is P/N 1993607. Search that number on ebay and Google. NOS ones do come up. (and I stole this photo from ebay, so not my little devil...)
joe_padavano is offline
Old April 23rd, 2024, 06:58 AM
Oldsfan's Avatar
I replaced my switch and it turned out to be a motor problem. You might want to investigate further.
Oldsfan is offline
Old April 23rd, 2024, 07:15 AM
Mikeyt
Mikeyt's Avatar
Awesome Thanks!
Mikeyt is offline
Old April 23rd, 2024, 07:18 AM
Mikeyt
Mikeyt's Avatar
Can I have your old switch? 😁
Yeah I've only had her for 2 days so haven't trouble shot anything even it it turns out not being the switch I'm thinking as hard as it seems to find parts like these having a spare or two isn't a bad idea.
Mikeyt is offline
Old April 23rd, 2024, 07:21 AM
Oldsdruid
rocketraider's Avatar
You have verified the wiper fuse is good?
rocketraider is online now
Old April 23rd, 2024, 08:08 AM
Mikeyt
Mikeyt's Avatar
I have not.
The switch just feels bad. Doesn't click on or off. Not sure it's even supposed to.
So yeah I have some troubleshooting to do.
Mikeyt is offline
Old April 23rd, 2024, 02:51 PM
Mikeyt
Mikeyt's Avatar
You called that one.
The **** was loose thats why it didn't feel like it was doing anything.
Got 12 volts to the motor but nothing happens.
Did you replace or repair your motor?
Mikeyt is offline
Old April 23rd, 2024, 02:56 PM
The wiper motor operates off ground/s provided by the switch.
oldcutlass is online now
Old April 23rd, 2024, 03:30 PM
Mikeyt
Mikeyt's Avatar
Ok
When the switch is off and I check power at the motor there is no power. Switch on we have power so I believe it's functioning as it should or is there more to it?
Mikeyt is offline
Old April 24th, 2024, 06:36 AM
Oldsfan's Avatar
I took the cover off my motor and cleaned the old grease out of it. That stuff gums up after many years and things stop moving. Needs a good cleaning and re-lubing. It's a pain, because you've got to pull the wiper arms and cowling to get at the bolts to remove the motor.
Oldsfan is offline
Old April 24th, 2024, 06:51 AM
Mikeyt
Mikeyt's Avatar
Thanks for the reply
Definitely looks like a pain but it's gotta be done.👍
Mikeyt is offline
Old April 24th, 2024, 10:47 AM
Mikeyt
Mikeyt's Avatar
All was going well. Got motor out. Wasn't too bad.
Everything looked brand new inside so I decided to pop the cover off the motor itself. Very very bad idea.
I have no idea how I'm gonna get these bushings back around the rotor.
Mikeyt is offline
Old April 24th, 2024, 01:00 PM
Oldsfan's Avatar
What bushings?
Oldsfan is offline
Old April 24th, 2024, 03:37 PM
Mikeyt
Mikeyt's Avatar
What bushings?
brushes. Dang auto correct
Mikeyt is offline
Old April 25th, 2024, 05:11 AM
Art S
Supernice88's Avatar
There are instructions in the service manual, it involves using paper clips bent to a certain shape to hold the brushes back.
Supernice88 is online now
Old April 25th, 2024, 06:51 AM
Oldsfan's Avatar
Yeah, you probably shouldn't have gotten into the motor. I was referring to the mechanism.
Oldsfan is offline
Old April 28th, 2024, 01:49 PM
Mikeyt
Mikeyt's Avatar
I managed to get it back together with some blue painters tape and a lot of luck.
Now I need to figure out how to test it properly.
Mikeyt is offline
Old April 28th, 2024, 02:22 PM
This will give you an idea:
Old April 28th, 2024, 02:31 PM
Ah Ha! Brilliant. I always wondered how to test the PARK function w/ a jumper wire. That was kewl.
Vintage Chief is online now
Old April 28th, 2024, 04:31 PM
Mikeyt
Mikeyt's Avatar
[QUOTE=oldcutlass;1567231]This will give you an idea:/QUOTE]
Thanks!
Mikeyt is offline
Pug Wrangler
June 15th, 2023 07:35 AM
spaceman_spiff
July 6th, 2017 09:12 PM
Ron Scobie
January 6th, 2013 02:41 PM
edfries
December 13th, 2012 06:00 PM
toms1966rgtop
May 15th, 2012 06:49 PM
Quick Reply: Wiper switch for 62 98
