Working Under the Dash is a Royal Pain.
Old October 21st, 2009, 11:09 AM
Dan Wirth's Avatar
I'm a fairly large guy and working under the dash is problematic. It would almost be worth loosing weight for, except that I have too many bucks invested in my waist line...
I needed to repair the wiring to my clock before the new quartz converted clock is returned to me, from D&M Restoration. I found the problems (open wire from the battery source to the clock itself, and another open wire to the clock lamp from the light switch).
I'm not looking forward to my next under the dash experience of tracing out my glove box lamp problem for the 57 Olds. I'd much rather give my car a tuneup and boil my carbs, than crawl around the back part of the dash!
Any tips out there for doing behind the dash work?
Dan Wirth is offline
Old October 21st, 2009, 11:37 AM
AZ442's Avatar
Dan, I feal your pain.
I have huge wiring problems under my dash ( fix 1 thing and somthing else quits working) finding out my arms don't go the the same positions as they did 20+ years ago.
The only advise I have for you is take the seat out so you can lay down get a good light and a small pillow for the back of you head. you will thank yourself for it.
good luck!
AZ442 is offline
Old October 21st, 2009, 12:20 PM
68Tom's Avatar
I agree. Removing the front seat is a must for any extensive job. Otherwise, it's just awkward and makes a difficult job even more difficult.
68Tom is offline
Old October 21st, 2009, 12:51 PM
Oldsdruid
rocketraider's Avatar
Make sure you have something to pad the seat mounting studs. They can cause yelps...
rocketraider is offline
Old October 21st, 2009, 01:42 PM
citcapp's Avatar
I agree take the seat out, unless you weigh less the 50 lbs and no taller then 3'-2" it's just a bear
citcapp is offline
Old October 21st, 2009, 04:44 PM
Dan Wirth's Avatar
Taking out the seat seems to win hands down when working under the dash. Well worth the additional work, especially at my (approaching) dinosaur age.
Thanks for your responses.
Old October 21st, 2009, 05:58 PM
71 cutlass convertible
lshlsh2's Avatar
I guess I will be taking out the seat in my cutlass this winter as I plan to chase down some shorts in my dash. What fun.
Larry
lshlsh2 is offline
Old October 21st, 2009, 06:20 PM
68conv455's Avatar
The studs for the seat mounts are absolutely a pain. I've been dealing with this sorting out the spagetti under my dash. Lay something down over them if you can. My curtesy light system is the final frontier I'm going to tackle.
68conv455 is offline
Old October 22nd, 2009, 02:57 AM
Yellowstatue's Avatar
Wink Great void
Try taking the glove box out, then you can see what you are doing for the GB light and if the radio is out then you can see right to the clock...its a hell of a lot easier working on the '57 dash than the the Aurora dash
Yellowstatue is offline
Old October 22nd, 2009, 03:12 AM
olds..older..oldest
derek nesdoly's Avatar
Midgets and Dinosaurs
I had to repair my tic-toc-tach and do the quartz clock conversion on my 69 442. At 6'5, 220 lbs, my head was under the dash [with eyes,nose and mouth catching all that dried up yellow foam dust!], and my feet were on top of the front seat back! Luckily,my near dwarf-sized mechanic was a better "fit",and a few beers kept the swearing and complaints down to a dull roar.Dan, work out these issues,so that when I get MY 57 [if Yellowstatue ever gets back to me!!],I'll be able to hit you up foradvice Derek
derek nesdoly is offline
Old October 22nd, 2009, 03:16 AM
olds..older..oldest
Oh, and by the way,seeing as there's a "Land -Yacht" group on this site, should not we "Dinosaurs" also band together to avoid a second extinction?? Comments welcomed!!
Old October 22nd, 2009, 07:44 PM
Dan Wirth's Avatar
Took the glove box out and was glad I did - put lots of light where I needed it and could get around a bit better. Could not fix my glove box lamp, as I need the GB light and Switch Assembly (switch is bad) - do you know where I can find one?; also no 12V at the GB light and will need to trace that out. I would hate to do any under dash work on my Aurora - I can't believe how tight everything is compared to the 57 Olds.
Good luck with that. Got mine working awhile back and ohhh what fun!
Amen to that Brother!
Old October 23rd, 2009, 02:59 AM
Thumbs up Lighten up
Dan; someone on this site is parting a '57 98 four door with air (complete air for sale) so he should have a glove box lamp for you
Old October 23rd, 2009, 07:07 AM
Dan Wirth's Avatar
I just saw that late yesterday and have left him a message for the part.
Thanks.
Old October 23rd, 2009, 08:10 AM
Oldsdruid
Try turning on the park or headlights and see if you have 12v at the glovebox switch.
Up thru about 1970 Oldsmobile wired underhood, glovebox and trunk lights thru the taillight circuit. Idea was that if the lights were off, one of those lamps couldn't drain the battery.
Old October 23rd, 2009, 05:30 PM
Dan Wirth's Avatar
You just solved my problem. I must have been driving around with no tail lamps because I found a blown fuse. Replaced it and everything works on that circuit including the glove box light.
Thanks very much,
Dan
Old October 23rd, 2009, 07:37 PM
67 heavy metal
delmontcrusier's Avatar
That is what I found out on my car it was odd I didn't figure that out till I had the hood open and was working on my headlights and that is when I found out how that circut worked the trunk light has I belive a merc switch so it goes off when the lid is closed not shure how the hood one goes off as I never seen a merc switch.The glovebox lite has constant power though.I too know the horrors of wiring frusteration as I had to rewire half my dash with the mess I had.
delmontcrusier is offline
Old October 23rd, 2009, 09:14 PM
Randy C.
rcorrigan5's Avatar
Removing the steering column can give you a lot more room as well.
Randy C.
rcorrigan5 is offline
Old October 23rd, 2009, 09:46 PM
Registered Abuser
Red Delta's Avatar
Oooooh, what is this Quartz conversion that people are speaking of? I figure that someone out there is modernizing the mechanical clocks?
My clock works for about a day if I give it a tap. Kind of annoying. Where is a good place to get the parts needed for the conversion? Not a chance that I'm going to send my clock away in the mail, I will do it myself, thank you very much.
Red Delta is offline
Old October 23rd, 2009, 09:53 PM
I bleed Oldsmobile
BIGJERR's Avatar
Fairly big guy huh?
Iam in the 350lb range I have to have a skinney buddy help me out when I have to get up under there! lol
BIGJERR is offline
Old October 23rd, 2009, 10:58 PM
Dan Wirth's Avatar
I think that the engine light switch for a 57 Olds must be a the same as the trunk light switch. It does turn off the same way as the trunk light. Mine is disconnected and am glad it is, for the car shows and all the work I've been doing on the engine lately.
Randy C.
I've never tried that but I guess there's always a first time. Sounds complicated and somewhat intimidating; but like they say "No guts, no glory" (I suppose).
Yeah, I know that pain. But I carefully sought this place out and insured my postage for $400 just in case the clock got lost in the US Mail. Fortunately. I have a backup clock (also in need of repair) that I want to keep original and will be having it repaired once the other one is quartz converted and returned.
You know, most problems with these clocks involve a simple but thorough cleaning. It is recommended that when you clean them, go to a watch maker for the right solution, along with getting a can of air. I took one of the clocks apart and it did not seem that complicated - but it's easy to say that because I really didn't delve that far into it. Clocks are really not my thing, so I'd rather send them out.
Good luck on yours.
Originally Posted by BIGJERR
Fairly big guy huh?
So am I, plus I'm 61 y/o crawling around under there like a young man of 25. Who says the big dino guys can't kick a little butt once in a while. Hey man, this is my life and there ain't nothin keepin me from it (but I will admit, there are other jobs on the project I like a heck of a lot better)!
Old October 25th, 2009, 08:29 AM
I bleed Oldsmobile
BIGJERR's Avatar
I hear ya........I can throw around tires and engine blocks but under dash wiring is a farm out! lol
BIGJERR is offline
Old November 11th, 2009, 07:53 PM
Dan Wirth's Avatar
Just got my clock back from D&M Restoration, out of Greenville, SC, installed it and it is working great on the quartz conversion. All the guts were changed out and the shell casing, face, etc. remained the same; they also polished the chrome and painted the hands. Cost was $182.00. Got all the under dash wiring straightened out (loose connector).
Nice to see a working clock in the old girl...classy.
Rickman48
March 23rd, 2013 01:06 PM
kevin.horton
June 19th, 2011 05:57 PM
oldzy
Suspension & Handling
January 1st, 2011 08:06 PM
Z3d
Ninety-Eight
October 11th, 2009 02:58 PM
American Lead
March 17th, 2009 10:51 PM
Quick Reply: Working Under the Dash is a Royal Pain.
