1959 Drum Break Question????
Hi all, I'm doing the entire break system on my 59 and have a question. I got replacement front drums, had the old ones pressed off hub. Was told not to press the new ones on, but then the hub won't sit flush the drum due to the lip around the studs. Make sense??? Should I just put new studs in the hub, or open up the holes on the drums a little??
Any thoughts??
Thanks,
Kensey
Any thoughts??
Thanks,
Kensey
Any thoughts??
Thanks,
Kensey
Any thoughts??
Thanks,
Kensey
Any thoughts??
Thanks,
Kensey
Any thoughts??
Thanks,
Kensey
By the way, unless your drums are broken, they are BRAKE drums...
455Olds
Brakes/Hydraulic Systems
December 8th, 2013 08:16 PM
Oldssupreme
January 29th, 2013 07:03 PM
1carsick
23
October 2nd, 2012 05:50 PM
