1966 oldsmobile 330 engine head bolts and manifold bolts
Old July 27th, 2015, 06:46 PM
stanzaschance's Avatar
Cool 1966 oldsmobile 330 engine head bolts and manifold bolts
Can someone tell me where I can buy Head and manifold bolts for 1966 oldsmobile 330 two barrel carb. Thanks,any info would be appreciated.
stanzaschance is offline
Old July 28th, 2015, 04:19 AM
car nut farmer
71rocket's Avatar
Most well stocked auto parts stores should handle them, NAPA for one.
71rocket is offline
Old July 28th, 2015, 06:38 AM
If you need the head bolts with the stud on top for accessory mounting, you won't find them aftermarket except from an Olds specialty vendor. More to the point, you don't need to replace your head bolts if they are in good shape. These are not torque-to-yield like on newer vehicles, so they can be reused if not damaged. Manifold bolts can be replaced with grade 8 bolts from a hardware store if needed.
joe_padavano is online now
stanzaschance
August 12th, 2015 07:45 PM
nolabigdawg
October 25th, 2014 11:50 AM
Olds Scott
May 29th, 2013 08:15 PM
Eightupman
November 13th, 2012 05:16 AM
1966_F85
May 8th, 2010 07:49 PM
Quick Reply: 1966 oldsmobile 330 engine head bolts and manifold bolts
