1970 Cutlass brake booster
Old June 22nd, 2014, 07:16 PM
Mr Shifty Sidney's Avatar
Planning a front drum to disc conversion using factory parts. Are the boosters the same for all drum and disc /drum? Do I need to change the booster for this conversion?
Don W
Mr Shifty Sidney is online now
Old June 22nd, 2014, 07:26 PM
oldspackrat's Avatar
Don,
I'm pretty sure the booster itself is the same for any car with power brakes. I know the master is different between manual drums or discs & power drums or discs & the rod inside the car might be different depending on if you're going from manual to power.
I'm sure others know more specifics.
oldspackrat is offline
Old June 22nd, 2014, 09:48 PM
Don W
The boosters carry different part numbers, but I've never been able to tell the difference. I've done may disc conversions on A-body cars without changing the booster and had no problems.
joe_padavano is offline
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 03:22 PM
cmyolds442
July 7th, 2013 10:31 AM
w31man
January 7th, 2013 04:31 PM
virtualwsp
June 13th, 2012 02:00 PM
smcurro
October 14th, 2011 12:55 PM
Quick Reply: 1970 Cutlass brake booster
