1972 Cutlass rear window trim
They make a hook type tool, just for removing the trim. Lot of car parts store, should have it. You slip it under the trim, and release the clips that that hold it. I put duct tape, on the bottom of the tool. as you can scratch the window.
Also on the rear window trim, don't forget that the bottom stainless has screws with nylon bushings that need to come out.
