3 1/2 years and lots of cash later...
My '69 Cutlass S convertible is finished. Just in time for a long Maine winter!
I pretty much replaced everything cosmetic along with a full engine rebuild. It runs, drives, and sounds great; the way cars were before our oil troubles began.
Last edited by 69cutlassragtop; December 10th, 2012 at 05:16 AM. Reason: a few more pics...
Parts list:
reman. master cylinder
wipers, brake fluid, bl wrrench
4 OEM wheels used 14x7
RH tail light assy
RH tail lamp bezel
Left inner headlamp bezel & bucket
wheel emblems
trunk trim
trunk badge (fender not trunk)
left outer headlight bezel
body and service manuals on disk
4 wheel brake shoes and cylinders
2-headlight housings
brake shoe cores
brake booster
antenna
tail lamp socket, bulbs, bumper bolt
hood bumper bolt
glove box
AM radio dash speaker
upper,lower,bypass, molded hoses
air filter
fuel filter
pcv valve
fan-alternator belt
upper radiator hose (alt belt cut)
20 - lug nuts
4- BG Goodrich TA Radial RWL
graphite wheel paint - return
bypass hose - return
car cover
L.U. fender moulding
L.F. eyebrow moulding
used battery
2- outside door handles
battery shut-off
wire ties
bulbs
4- window cranks
front seat covers
rear seat covers
front door panels
rear door panels
seat buns
rear armrest covers
window sweep kit
rear courtesy lenses
carpet
SEM landau black interior paint &prep
3M Super Trim Adhesive
used seat backs
door handle buttons
POR-15 prep and paint - floorpan
shift indicator lense
shift seal
rocket 350 decal
4000 sealed beam
lock *****
seat chrome trim
front seat side support springs
install seat covers + spring repair
trim fasteners
trim hardware
headrest escutcheons
quarter window chrome and seals
door sill plates
armrest bases and plates
3m weatherstrip adhesive
door panel fasteners and screws
quarter window seals
rear bumper
washer bottle
rearview mirror
fender bumpers
air cleaner tube
brake pedal pad
hood hinges
14x7 SSII wheel
hood to cowl seal
AC condensor mounts
radiator repair clean/solder tank
radiator cap
Complete engine rebuild
R&R engine, parts & labor
heater core and blower motor
harness clips and door hinge kit
heater hoses & antifreeze
heater control valve
RF inner fender bolts
defroster hose
L&R motor mounts
sport steering wheel & hub
speedometer cable
horn contact
horn cap
front bumper
repair oil filter adapter leak
mirror, exterior emblems
5-wheel well moldings
used hood
new convertible top
convertible top hoses
paint resoration
side marker bezels - replace lost
side marker gaskets
bumper fillers
hood insulation
hood bumper
peak molding clips -12
shipping & handling
quarter window roller
AC Delco fan clutch
2- window cranks - oem hq
4 - Halogen headlamps & AC Delco dimmer switch
headlight sockets and trunk paint
dual exhaust w/Dynomax Turbo mufflers
upper & lower ball joint, pass. side
RH tail light assy
RH tail lamp bezel
wheel emblems
trunk trim
brake shoe cores
brake booster
antenna
hood bumper bolt
glove box
air filter
fuel filter
pcv valve
fan-alternator belt
20 - lug nuts
car cover
used battery
battery shut-off
wire ties
bulbs
4- window cranks
front seat covers
rear seat covers
front door panels
rear door panels
seat buns
rear armrest covers
window sweep kit
carpet
used seat backs
door handle buttons
shift seal
rocket 350 decal
4000 sealed beam
lock *****
seat chrome trim
trim fasteners
trim hardware
door sill plates
rear bumper
washer bottle
rearview mirror
fender bumpers
air cleaner tube
brake pedal pad
hood hinges
14x7 SSII wheel
hood to cowl seal
AC condensor mounts
radiator cap
defroster hose
L&R motor mounts
speedometer cable
horn contact
horn cap
front bumper
used hood
new convertible top
paint resoration
side marker gaskets
bumper fillers
hood insulation
hood bumper
shipping & handling
AC Delco fan clutch
