3-row to 4-row; Need Input
Old June 15th, 2010, 04:03 PM
nelsontj's Avatar
I want to upgrade the radiator from a 3-row to a 4-row on a 1970 442. The factory set-up was a 3-row, four blade fan, no fan clutch and no shroud. Are any radiators better than others and will one fit on like the original? Do I just go to a parts store and order a replacement, or should I get it from of one of the Olds speciality vendors? I don't want to get into one of those "universal fit" situations where I have to make a bunch of alterations. Will there be issues with going from a 3 to 4, such fitting the core support? I realize I will have to get a different top plate to fit a 4-row. The set-up is for a manual transmission so lines will not be an issue. ...And the big question I probably should ask to begin with: Will the upgrade be a big improvement over the 3-row, or should save my money for the coming world economic melt-down?
nelsontj is offline
Old June 15th, 2010, 04:25 PM
71 & 72,now I want a 68
w-30dreamin's Avatar
As far as the actual radiator...
I found a link on the board recently to this place.
They have Harrison radiators and some very nice looking aluminum reproductions that are direct fit,very efficient and can be painted or left raw.
Nose around at the site for a while and read,you might find something that interests you...I did.
http://www.alumitechreproductions.com/58.html
w-30dreamin is offline
Old June 15th, 2010, 04:35 PM
compedgemarine's Avatar
they are not really a "direct" fit. both the steel cradle and rubber inserts are different from the 3 to 4 core. you can buy the steel cradles and drill out the spot welds on the radiator support and weld on the new ones. the top bolt on support needs the cradles cut off and trimed and the new ones welded on. with basic skills and a welder it is pretty easy to do. I have done several and if you have a spot welder no one has been able to tell them from originals.
compedgemarine is offline
Old June 15th, 2010, 05:24 PM
442Harv's Avatar
Are you upgrading, because you have a problem? If you have a heating problem, I would change to a clutch fan first. Also this car came this way, and probably did not overheat, so maybe figuare out why it is over heating, before you make a lot of changes.
442Harv is offline
Old June 15th, 2010, 07:54 PM
Blk71SX's Avatar
Fusick offers the top plate with insulators and lower cradles with insulators. the lower cradles are spot welded but aren't too difficult to remove. a couple of 3/16" pop rivets will secure each of the replacements. the location of the lower cradles is critical for proper fit of the radiator. measure twice, pop once.
also, on the cars with shrouds there are two brackets that anchor the lower shroud that would have to be moved rearward.
Blk71SX is offline
Old June 16th, 2010, 02:33 PM
ELECMAN's Avatar
did you think about putting and aftermarket expanson bottle and shroud on the car before spending money on a radiator
ELECMAN is offline
Old June 16th, 2010, 03:11 PM
nelsontj's Avatar
I plan on putting a shroud and fan clutch on. I plan I driving the car a little farther distances than I have done in the past. I just want input on whether putting in a 4-row radiator is overkill. I don't have air conditioning on the car. As far as I know, if I do put in a 4-row I will have to change the brackets and the top plate. Is there anything else that has to be done?
nelsontj is offline
Old June 16th, 2010, 03:20 PM
defiant1's Avatar
https://classicoldsmobile.com/forums...r-install.html
The above link describes the the aluminum 2 row (http://www.speedwaymotors.com/Speedw...ator,5391.html) I put in my car. Modifications were necessary, so far I am happy with the radiator. I still have the stock fan, no shroud, no fan clutch, and I have A/C.
For the price it was not a bad option for me.
Side note: Speedwaymotors (due to my negative review of how the radiator was advertised as a direct replacement) has added a "Note" to ensure that people are aware that the radiator desciption is for reference only. And measurements should be made, etc. before purchasing.
d1
defiant1 is offline
Old June 16th, 2010, 03:35 PM
Blk71SX's Avatar
a shroud, AC Delco thermo fan clutch and a 6 or 7 blade HD fan with the 4 row will make you as cool as the Fonz
Blk71SX is offline
Old June 16th, 2010, 03:48 PM
442much's Avatar
I put a 4 row rad in mine years ago. I didn't have to change the top plate. My 442 came with a seven blade fan, no clutch, no air but it did have the shroud. I'm surprised to hear that the 70 442 came with a 4 blade fan.
442much is offline
Indy_68_S
November 24th, 2010 07:52 PM
shaks 442 clone
December 19th, 2007 01:46 PM
dar83501
Ninety-Eight
23
December 10th, 2007 03:24 PM
tex70
April 30th, 2007 08:46 AM
cwd56
October 22nd, 2006 10:54 AM
Quick Reply: 3-row to 4-row; Need Input
