350 Rocket Question
All Oldsmobile V8 motors since 1949 were called "rocket". It's a marketing name, and apparently a very effective one, given that 75 years later, people still thinks it actually means something.
The one exception is the 1961-63 aluminum 215. Of course, that was really a Buick motor anyway.
Originally the newly designed 90 degree Olds V8 was to be named in honor of Charles “Boss” Kettering hence the name on the sign in the photo above. The text explains where the name Rocket V8 came from.
Basically bore spacing and overall architecture are the same. Interchanges include front cover, timing chain, cam, distributor, water pump (allowing for the fact that there are different lengths), crank (with a little work on the rear main seal), oil pump, some valvetrain parts, some accessory brackets. The SBB is essentially a taller deck version of the 215. The 215 intake works on the Buick 300 with spacers. The Buick 300 heads are a popular upgrade on the 215 due to larger ports and valves (64 300 motors used aluminum heads).
the Olds is 32 pounds heavier overall. The Buick 215 heads are basically scaled down nail head design from a 1955 design.
ya sure the Buick engineers did the basic design but Olds changed what was junk. Added the 6th bolt in the deck and added beef where needed. They were done in different assembly lines. I have an old book somewhere that talks about other small design changes done by Olds…if I find it I’ll post it
the Olds heads and rocker assembly are Olds designs. Buick 215 head won’t work on the Olds 215 block
can you show me where they used it to describe the 260 or 307 in any of their advertising?
i have a 307, it’s a Rocket….but not by GM’s description that I can find
z11375ss
July 11th, 2023 11:02 AM
