69 olds F-85 2 speed jetaway trans i believe its also called a superturbine 300
Old September 1st, 2013, 07:53 AM
dabull55's Avatar
looking to solve my morning /cold trans start up . when the trans is cold ,it takes several miles to warm up and finally shift into second gear ,after that first shift it runs great ,changed the filter ,no difference,any clues
dabull55 is offline
Old September 1st, 2013, 08:11 AM
Make sure it's full with the engine running and completely warmed up. Check your vacuum line to the modulator and verify that the modulator is not leaking fluid. Normally this problem is from a leaking rubber hose or a bad modulator.
oldcutlass is online now
Old September 1st, 2013, 08:22 AM
dabull55's Avatar
thanks i try that ,fluid is full ,did find the hose on the top loose before ,clamped in down . but going to check the rest of the line /tubing going to the modulator
thanks again
dabull55 is offline
rcdynamic88
August 1st, 2013 03:44 PM
1956OldsDarrin
January 23rd, 2011 12:11 PM
VikingBlue
June 4th, 2010 03:07 AM
thorpedo91
May 26th, 2009 05:43 PM
woodie582
July 21st, 2008 05:53 AM
Quick Reply: 69 olds F-85 2 speed jetaway trans i believe its also called a superturbine 300
