76 Hurst Hatch?
Old April 4th, 2011, 01:50 PM
jensenracing77's Avatar
76 Hurst Hatch?
i located a 76 cutlass top that is cut off the car. it has Hurst Hatch T tops in it. the tops look like they are in pretty good shape but i don't know the condition of the metal around the tops. i don't even know what he is going to want for them. are these something i should look into? are they a desirable enough part to make it worth my time to investigate? i know nothing about 76/77 cutlasses. i can also get a gauge cluster from the same car. any info would be great, thanks.
jensenracing77 is offline
Old April 4th, 2011, 09:04 PM
442much's Avatar
Go check the parts out if they are close to you. Does it look like this? This one has weatherstripping, headliner, dome-reading lamps, and visors, in Buckskin. Try and get the weatherstripping included as it sells for about $500 by itself.
442much is offline
Old April 5th, 2011, 02:12 AM
it looks like that but i don't think these had the trim around the glass part. it just had the trim at the drivers and passenger edge. on the center side, it had two little chrome tabs that hooked under the center of the car top. the cars top had the trim all the way around. what about the gauge cluster?
Old April 5th, 2011, 06:55 AM
442much's Avatar
Apparently there is a first generation and second. I don't know which is which. I think Fusick sells used Hurst Hatches.
442much is offline
77olds
January 19th, 2014 09:47 PM
m455sx
March 21st, 2013 11:53 AM
brownbomber77
May 29th, 2012 09:06 PM
red rag top
May 6th, 2011 06:17 AM
frankenstein
December 3rd, 2007 01:29 PM
Quick Reply: 76 Hurst Hatch?
