Asbestos Donut in exhaust Pipe to exhaust manifold
Old May 29th, 2013, 12:16 PM
atkinsom's Avatar
I have a 1969 455. I'm looking to get the asbestos type donut that fits into the exhaust pipe that attaches to the w-z manifolds and flanges that I've bought. I don't know that name of that part but would like to know what that name is and where to buy it. Inline and fusick don't carry it. Thanks again.
atkinsom is offline
Old May 29th, 2013, 12:19 PM
72 Olds CS
RetroRanger's Avatar
rockauto lists it i wold expect napa or any good auto parts place can get it
FEL-PRO Part # 60241
Packing; 2 1/8" ID
$5.58VICTOR REINZ Part # F7187
RetroRanger is offline
Old May 29th, 2013, 12:37 PM
65B01Delta's Avatar
I don't think the W & Z manifolds take the donut.....
65B01Delta is offline
Old May 29th, 2013, 01:06 PM
Rickman48's Avatar
Any good exhaust shop should have it in stock - bring your old one to match-up.
Rickman48 is offline
Old May 29th, 2013, 01:09 PM
mmurphy77's Avatar
No donut required. The down pipe should be flanged to mate with the 'ball' end of the collector on the manifolds.
mmurphy77 is offline
atkinsom's Avatar
Thank You Retro..now I know the proper term so I can search better.
Delta and Murphy...I always thought the donut was universal for all Olds based on my reading, thanks for clearing that up...I'll let the muffler shop deal with it.
atkinsom is offline
Old May 29th, 2013, 01:39 PM
You might want to do a little research before you let them "deal with it". As noted above, the W/Z manifolds - actually any A-body manifolds - not only do not use the donuts, they cannot accept one. Manifolds that use donuts have a machined counterbore or a female taper on the inlet end of the manifold. The donut either has a short steel ring that fits into the counterbore or has a double taper cross section to fit into the manifold as well as into the flared pipe.
The Olds manifolds have a machined male taper on the outlet. There is no physical way to install a donut, nor was one ever used from the factory.
Note how this manifold has a counterbore for the donut:
Now look at the outlet end of these Olds manifolds:
Then there's this Olds 350 manifold, which has the male metal taper on the crossover port but is cut for a donut on the outlet port:
joe_padavano is offline
Old May 29th, 2013, 06:39 PM
atkinsom's Avatar
Thank You Joe...appreciate the info.
atkinsom is offline
matchek
March 16th, 2015 04:23 AM
rmoths
July 9th, 2014 03:26 PM
805cut
June 8th, 2012 03:15 PM
Cutty72
Wheels and Tires
October 2nd, 2011 03:27 AM
RAMBOW
August 12th, 2009 06:24 AM
Quick Reply: Asbestos Donut in exhaust Pipe to exhaust manifold
