Best aftermarket air filter size ???
Finally purchased an Edelbrock performance 4 barrel carb to replace the stock Rochester 2 barrel carb on my 1966 delta 88 .What would be the best size Edelbrock air filter assembley to run with this setup??
Minimum 14" diameter which is pretty much a standard size. Height is personal preference. An open element aircleaner can accept about any height element your hood will clear. I've run many 14x5 or 6 inch tall elements which were easy to find as they are common on trucks.
Keep in mind that although a taller element gives you more effective filtering area, one too tall may influence weird airflow between element and carb airhorn and actually hurt performance.
Two ideas if pure originality not critical - Find a factory 4BBL air cleaner even if not the exact year or get any generic open element air cleaner and put the appropriate olds decal on it (was taking picture of the compressor but you can see air cleaner cover). Personal preference only, and don't like the red pleated filter lids and/or small diameter elements.
http://www.summitracing.com/parts/sum-g3000/overview/
The filter is a flow restriction (and becomes more of one as it becomes dirty). The larger the filter area, the less of a restriction. 14" x 2" is common. 14" x 3" is available for even less restriction.
oldspackrat
March 21st, 2016 05:17 PM
joepenoso
July 19th, 2013 12:44 PM
