Braided lines
Old June 3rd, 2015, 08:21 PM
Cutlass455's Avatar
Braided lines
I have a 455 olds and am curious to where I can find steel braided fuel lines to the carb? naybr any other line as well, looking to spice up my motor
Cutlass455 is offline
Old June 3rd, 2015, 08:22 PM
steverw's Avatar
Jegs or Summit Racing would be good places to look.
steverw is offline
Old June 4th, 2015, 05:53 AM
Be aware that you won't find pre-made braided lines for your car. You have to buy the bulk hose, end fittings, and adapters all separately and cut and assemble them yourself. Personally I prefer Earl's Supply, as they are one of the first and still the best-stocked suppliers. It also helped that I used to live only a few miles away from them.
Also be aware that the inner lining of braided hose is just rubber tube (I'm not talking about the small-diameter high-pressure teflon-lined hose here). The rubber deteriorates just like any other hose. I've had braided fuel hoses where the rubber went bad and gasoline just seeped out between the stainless braid.
Frankly, I've gotten over my braided hose bling phase. It's lots of money for no performance benefit.
joe_padavano is online now
Old June 4th, 2015, 11:32 AM
Seff's Avatar
...What's the point, then? Is the braiding for heat shielding or just for general protection and bling effect?
Seff is offline
Old June 4th, 2015, 12:27 PM
The braiding is there to protect the hose. It was designed for use in hi vibration applications and to enable flexibility without chaffing or cracking.
oldcutlass is offline
Old June 4th, 2015, 12:48 PM
It's used for stiffness for either vibration, like said above, or keeping it out of the way of moving parts. It's also to avoid cataclysmic failure, both in terms of machine health, and user health if your job is working next to one.
In the car world, it's used as a fashion statement, and an example of the "More than necessary is better" old saw that is common amongst the non-engineer enthusiasts of the car hobby.
Use a good, new hose of good brand and proper diameter and good clamps, and check under the hood every fill up.
Koda is offline
Old June 4th, 2015, 01:59 PM
BlackGold's Avatar
I wouldn't call braided hose "bling" or "a fashion statement" when it comes to fuel lines in the engine compartment, especially at the front of the motor where there's spinning belts and a fan blowing any leak toward ignition sources. Ideally you use rigid tubing, but braided is safer than bare rubber hose.
BlackGold is offline
Old June 4th, 2015, 02:11 PM
83hurstguy's Avatar
If you're serious about performance hose (and not bling), this stuff is close to the best stuff you can get. It's impressive... very light and flexible.
https://www.pegasusautoracing.com/pr...p?Product=3490
They do sell it stainless braided (slightly cheaper) as well:
https://www.pegasusautoracing.com/pr...p?Product=3480
Just be sitting down when you check the price.
83hurstguy is offline
Old June 4th, 2015, 02:14 PM
If rubber hose is a 3 in terms of safety, and rigid tube is an 8, then braided hose is a 4. I presume everyone carries a fire extinguisher in the cab with them?
Koda is offline
Old June 4th, 2015, 02:47 PM
Beer Connoisseur
70cutty's Avatar
Summit is best bang for the buck.
You will probably need -an to tube adapter fitting, couple of hose ends and couple of feet of hose. It can be done relatively easy.
I've done stainless from fuel tank to carb, also I've done my transmission cooling lines in stainless to get them away from the headers.
70cutty is offline
Old June 4th, 2015, 05:36 PM
Cutlass455's Avatar
Can you send me links to the stuff you got? That's what I'm looking!!
Old June 4th, 2015, 06:00 PM
I'm not too much into the shiny crap, but those valve covers look REALLY nice.
MDchanic is offline
Old June 4th, 2015, 06:07 PM
m371961's Avatar
The problem with braided hose is you cannot see the rubber when it is deteriorated. The braid protects against abrasion and the chance of it spraying.
m371961 is offline
Old June 4th, 2015, 07:33 PM
mrhotrod's Avatar
If you plan on any drag racing you are not allowed more than 12inches of rubber hose. the rest has to be solid line or steel braided is accepted. the neat nylon plastic lines they use on new cars is only accepted as factory installed. has to pass through a metal tube or outside the frame where it passes the flywheel area. the braided lines are a pita to do and they do leak right through the braids I have had the best luck with Aeroquip stuff . I use 1/2 inch fuel line with 1/2 return line from the regulator so there is a lot of fuel flowing constantly keeps the temperature constant. I prefer the braided lines over anything else at this point even with the pain of assembly , and I mean that literally lol
mrhotrod is offline
Old June 4th, 2015, 07:36 PM
mrhotrod's Avatar
you might check, if you buy the stuff at one of our local speed shops they will cut and assemble them for you to your specs free.
mrhotrod is offline
Old June 5th, 2015, 06:37 AM
Rallye469's Avatar
I like the Russell ProClassic II.
The steel braiding is on the inside, less bling, easier to work with than the stainless...good stuff.
-Pete
http://www.russellperformance.com/mc...lassic-2.shtml
Rallye469 is offline
Old June 5th, 2015, 09:48 AM
Beer Connoisseur
70cutty's Avatar
Thank you Eric.
not so much bling, no chrome whatsoever.
Everything is either aluminum or stainless steel. I live couple of blocks away from the beach, and I take frequent rides down the coast so surface rust is my worst enemy. That is the main reason...... well it looks damn good too.
70cutty is offline
Old June 5th, 2015, 09:57 AM
That salt smell is nice, but it means rust.
Koda is offline
Old June 5th, 2015, 01:37 PM
Salt + aluminum = hrs of constant cleaning and polishing enjoyment. Your engine looks awesome 70cutty
Old June 5th, 2015, 04:29 PM
mrhotrod's Avatar
(I like the Russell ProClassic II.
-Pete
http://www.russellperformance.com/mc...lassic-2.shtml )
might be pretty good, I am not to sure it would fly through tech though. depends on the day and what race you are at, some can be very nit picky. the pro race stuff would pass np though .. I am going to have to rebuild all of my fuel lines since they are about 15 years old now. should be a lot cheaper this time if I can re-use most of the fittings.
mrhotrod is offline
Old June 6th, 2015, 03:29 AM
Rallye469's Avatar
Mrhotrod, I started using this stuff after first seeing it on Bill Travatos 7.8 second starfire. It'll pass tech for sure.
-pete
Al Sanchez
March 30th, 2024 02:17 PM
tmatador
February 27th, 2013 03:55 PM
defiant1
April 2nd, 2011 09:58 AM
Dan Wirth
October 8th, 2009 11:56 AM
Redog
December 29th, 2007 09:13 AM
Quick Reply: Braided lines
