Brazing an engine block?
Old April 27th, 2024, 04:01 PM
Rallye469's Avatar
Can this be fixed?
Just picked up this engine at Carlisle and thought I looked it over well.
Its the correct date, ‘65 B block, A heads for one of my 442’s so I’d love to save it.
(I do have other blocks I could use to help repair it)
As you can see one of the starter bolt holes is cracked in half.
Rallye469 is online now
Old April 27th, 2024, 06:39 PM
OLDSter Ralph's Avatar
Do you know a good welding shop where they know how to braze cast iron ? Brazing a couple broken pieces together is different than building up an area with brazing rod.
OLDSter Ralph is offline
Old April 27th, 2024, 07:20 PM
You need someone that can weld cast iron.
oldcutlass is online now
Old April 27th, 2024, 07:55 PM
66_Jetstar's Avatar
There is a nickel rod available for tig welding cast iron. I just had a fairly substantial repair done on a very rare Buick cylinder head.
66_Jetstar is online now
Old April 27th, 2024, 11:56 PM
4speed455's Avatar
I had a 350 with a similar break. I didn’t have the missing piece so a buddy of mine welded a bolt to that location. I’m not sure what he used but he was able to get securely attached and it stayed that way for several years until I sold the car.
4speed455 is online now
Old April 28th, 2024, 01:36 AM
Given that the 800 lb GM starter hangs from that pad, I'd weld, not braze. Welding cast iron isn't the mystical voodoo that most make it out to be. There used to be an old school welder near me (who unfortunately passed away a few years ago) who routinely stick welded cast iron farm equipment. I had him repair a drill press base for me. That was over 20 years ago and still no issues. Nickel rod is a must. The repair is far enough from critical surfaces that I doubt you'll have a distortion problem. I assume you plan to go through the motor anyway, so critical surfaces will be machined no matter what.
joe_padavano is offline
Old April 28th, 2024, 03:37 AM
Rallye469's Avatar
Thank you for the different angles guys.
It gives me hope.
And yes, I was thinking it was a mystical practice that involved the dark arts.
Old April 28th, 2024, 07:10 AM
Old(s)GuysRule
67OAI's Avatar
Peter, there is at least one shop in Jax that should be able to weld repair that block. Used to be a cylinder head repair shop on 103rd street that did that type of work. There are probably others now.
67OAI is offline
Old April 28th, 2024, 07:53 AM
Rallye469's Avatar
Thanks Jim!
Old April 28th, 2024, 08:02 AM
66_Jetstar's Avatar
You might have to grind the existing bolt hole out and fill a larger area with the nickel. It'll be next to impossible to drill a straight hole thats half cast iron and half nickel. The bit will deflect to the soft cast iron, even in a jig. Drilling and tapping will be the most difficult part of the repair.
Old April 28th, 2024, 08:25 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Welder buddy welded an ear onto my 68 400 exhaust manifold with nickle rod. That was 40 years ago. Its still good. I remember him saying the key is to cool it down super slow, and do the usual good practice weld prep...v grinding, cleanliness etc..
He gas heated the whole manifold, welded then wrapped it in a asbestos heat blanket over night.
Grind/file it smooth and go.
droldsmorland is online now
Old April 28th, 2024, 11:12 AM
oldolds88's Avatar
I would also be sure to use the side brace for the starter, even if you have to fab one.
oldolds88 is offline
wr1970
September 8th, 2023 10:01 AM
gear head
April 14th, 2023 05:32 AM
Moegs
October 15th, 2022 08:36 PM
wpgjetfan
June 22nd, 2021 07:42 PM
Jeffs71
July 1st, 2020 12:53 PM
Quick Reply: Brazing an engine block?
