Column Shifter to Floor Shifter
I own a 69 Cutlass S with a 455CI and TH400 auto trans. I really want to go from the tree shifter to the floor, any price estimates on this conversion? As well as what will be involved or things I might not being thinking are involved. Thanks
Floor shift steering column non tilt $75.00-$150.00, with tilt, $300.00-$450.00.
Bucket seats, rebuildable cores, $150.00-$400.00.
New seat covers & having them installed, $300.00-$500.00.
Or, buying nice restored seats ready to go, $600.00-$900.00
Console & shifter & cable & wiring harness, $100.00-$350.00.
Bucket seat floor brackets, $40.00.
Floor shift speedo, $25.00-$50.00.
Trans. pan cable brackets $40.00.
All prices are close estimates.
You can save a few bucks by just removing the shift lever from the column when you do the conversion & also just leave the column shift speedo there too.
If you want correct parts, you'll need bucket seats from 1969-72. Those had the seat back release in the back, the '68 versions have it on the side.
Not cheap for sure, but you can find some deals now & then. We have a few sets of bucket seats if you do make the change.
Scott
c. 317-727-7041
Scott
c. 317-727-7041
I am not looking to go stock by any means, My car is far from stock, I have a 70 hood on my 69, and a 455 from a 73. so not stock is quite fine. And I really do enjoy my bench seat(especially because of the lady friend) but taking corners can be a not so enjoyable time.
If that is the case & what you are trying to address some newer buckets seats out of another type of car would probably suit you better. The stock buckets aren't all that supportive.
In that case you can hit up a junk yard & see what you like & check Summit for a shifter.
Scott
c. 317-727-7041
Scott
c. 317-727-7041
I just found this picture on Cardomain and This would be quite convenient but Im not sure how this would work on a 69 or if the Shifter would be at least some what comfortable to use. I am a big guy and I am 6'1" so My arm length is up there so would I be able to reach the shifter? Also the one pictured is the one im looking for.
http://www.cardomain.com/ride/325897...me#32589730024
Bitburger
December 30th, 2012 04:49 PM
