To disk brake or not to disk brake that is the question
Old May 1st, 2012, 10:18 AM
67 heavy metal
delmontcrusier's Avatar
I have been tossing the idea of disk front brakes for my 67 olds delmont for a few years now and cannot make up my mind.I had priced a kit from ssbc and each year it goes up in price.But it is a nice kit just not sure I want to spend the bucks.Then I came accross scarebird that sells kits with blueprints.For anyone not sure what I mean they sell brackets and hubs with either all the parts or a listing of what you need.That can range from ford rotors and corvette calipers or any range inbetween.The idea they state is to be able to go to the parts store to buy over the counter repacement parts that would other wise be hard or impossible to find.Now the all wheel drums work but getting them fine tuned takes time.I have one that always wants to grab faster than the other when I stop.I can deal with the drums for now.But this is more when the front brakes wear out if I want to just replace the shoes or upgrade to disk.So with that comments,ideas and suggestions welcome.
added unrelated for giggles I now have 425 post let the 425 v8's roar lol
delmontcrusier is offline
Old May 1st, 2012, 04:42 PM
ziff396's Avatar
I also drove cars for years with front drum brakes. No problems. It's just like anything, you just learned how to drive them and thats the way it was. I did convert my Cutlass to disc's. It was a good move. No fading, pulling when wet, and adjusting (fine tuning) them. The drums do actually have less drag though. JMO
ziff396 is offline
Old May 1st, 2012, 05:02 PM
Jaybird's Avatar
Drums Work For Me
Power Drum Brakes work for me. I'm happy with my (new to me) power brakes. I took the booster from my parts car, had Cardone refurbish it, then I installed it in my 67 Delta 88 Custom.
I had to replace the brake pedal arm as well because the hole for the push-rod is in a different position.
I have looked at Scarebired as well but these brakes seem to work fine for now.
Jaybird is offline
Old May 1st, 2012, 08:09 PM
67 heavy metal
My main thought is it will be easier to get parts if I upgrade.But with the amount of old cars on the road brake shoes should be available for a long time.I am used to disks on the front seeing most my vehicles have them.But then I have gotten used to the drums on my 67.One problem I have is one of the drums might need to be replaced due to some damage nothing that will cause a problem with stopping but it is still somthing to consider.I had to put different wheel studs in two of the holes on one drum hub and with the way it is now I could not put a standard 5 on 5 wheel on the hub.I have the unilug cragar and it works but will still have to be taken care of at some point.
Old May 1st, 2012, 08:31 PM
Lt. Buzzkill (ret.)
copper128's Avatar
Drum brakes work adequately if in good condition and properly adjusted.
But disc brakes work better and don't need adjustment. Plain and simple, they stop faster, straighter and can do it repeatedly if need be.
Yep, converting to discs can be pretty expensive. I look at it as an investment in safety, so I did disc brake conversions on both my Delmont and 442. Money well spent, IMO.
copper128 is offline
Old May 1st, 2012, 10:55 PM
67442HT's Avatar
Drum brakes work OK, but you need to realize that the cars and trucks on the road today all have disc brakes, and alot of them have 4wheel disc brakes. They can stop a lot quicker in a shorter distance than a drum brake car can. Most of them also have antilock brakes. We have to remember to not tailgate these cars with much better brakes than we have or we will be eating their rear bumper. When all the cars on the road had drum brakes, it wasn't as much of a problem as none of the cars stopped very well. I remember when I came off of the Interstate at 80 mph and had to slow down in my 67 442, I would have to pump the brakes and then let them cool off and pump them again to slow down for the exit. Drums are OK, but disc are better!!!!
67442HT is offline
Old May 2nd, 2012, 02:59 AM
Aron Nance's Avatar
In process of having both front/rear conversion kits installed on the Silver Bullet. Looks great, and am sure will provide quicker/straighter stops. Found the kits on Ebay, and happy with them, so far. Will post results of road trip in late June, going to Homecoming.
Aron Nance is offline
Old May 2nd, 2012, 06:29 AM
DeltaPace77's Avatar
This topic comes up quite often, and really depends on how you drive the car. If just cruising around, stopping normally, front drums should be fine. If high speed panic stops, drums will quickly fade, and you're wanting front discs. Also noticed, Speedway Motors puts together front disc kits for older cars at $240 bucks. #910-31912 full size Chevy and #910-31958 mid size. Maybe won't work for your application, but something else to figure in the mix.
DeltaPace77 is offline
Old May 2nd, 2012, 07:22 AM
None of those kits work on the 1965-1970 full size Oldsmobiles (Chevy full size is different). This is a problem for these cars, as no one makes new rotors for them, not even stock replacements for the factory disk brakes.
joe_padavano is online now
Old May 2nd, 2012, 07:51 AM
64Todd's Avatar
Opinion on disk brakes
I converted my car to disk brakes about two years ago. I drive my car in L.A. traffic often and with the amount of cell phone holding, latte swilling, distracted drivers here, I felt that the disk brake was a step in the right direction so that my family and I were just that much more protected. I have been very happy with the results. I saved my old hardware just in case a future owner might want to switch back to original.
64Todd is offline
Old May 2nd, 2012, 08:54 AM
cutlassjoe's Avatar
When I did my resto I had the drums replaced with 11" slotted rotors up front and over sized drums on the rear. What a difference in stopping ability and worth the money.
cutlassjoe is offline
Old May 2nd, 2012, 05:24 PM
1965cutlassragtop's Avatar
Just did a disc brake conversion, tubular upper & lower control arms, and steering linkage this past month. It's like driving a different car!! Power disc over drum all day....I also replaced all my brake lines, and rebuilt the rear drums. The wheel cylinders were junk, the drums were in rough shape so I bought new drums, springs, shoes & wheel cylinders for the rear. But next time I do anything to the rear it will be a disc conversion back there to match the front!!! But really, it shouldn't even be a question. Drum brakes suck by comparison. Now I can actually drive the car and stop the car. I was always driving in a glass car before cuz u never know when a car decides to pull out in front of u...drum brakes won't perform as well as disc, plain & simple.
Check out Right Stuff disc brake conversions...nice kits with quality parts at a reasonable price. I got my set for a little under $800 with power booster, master cylinder, complete brake lines, & powder coated calipers.
1965cutlassragtop is offline
Old May 2nd, 2012, 06:07 PM
67 heavy metal
These are some great opinions and points of view.I think this summer I will shop around and if I find the right deal or kit I might just do front disk.Rear drum does not bother me as I am used to it all my other vehicles are disk front and drum rear.Now thats not to say if I find a deal I like that I wont consider disk rears.Funding tends to slow things down and some of these companys want a fortune for the product.I know prices are always going up and they have to make a profit to continue with business.But I also know they do a decent markup.I will have to contact ssbc and see what the price has jumped up to now just for curiosity and referance.
Old May 5th, 2012, 01:33 PM
spyke's Avatar
im gonna be honset i went the junkyard and pulled everything i needed off of a 79 monte carlo then i sandblasted it sprayed it changed the upper and lower ball joints and everything bolted up just right the rotors werent that good so i bought new ones the break lines bolted right to the calipers no leaks. i prefer the pads on the front because theyre simple to change instead of having drums all around.
spyke is offline
Old May 5th, 2012, 07:58 PM
67 heavy metal
What all did you need to do it.I have a junkyard not far from me that has old cars yet.But my car has the speedometer in the front driverside wheel so will this still work or is your car a different model.
Old October 12th, 2014, 08:10 PM
67 heavy metal
I did see a kit from scarebird it gives you key parts and gives you a list of what to buy to convert your car.
Old October 13th, 2014, 06:40 AM
Since you've brought this thread back from the dead, I'll once again point out that using later spindles on early cars is a REALLY bad idea. The ball joints use different tapers, so while you can bolt them up, the ball joints will NOT be loaded properly. At some point this will cause either the holes in the spindles to be elongated or the ball joint studs to break. Neither result is good.
Yes, it IS possible to retrofit the matching newer ball joints to the early control arms. The uppers are easy. The lowers require the outer housing of the new ball joints to be turned down to fit the LCAs. The outer tie rod ends similarly need to be changed. Of course, even if you do this, the steering arms are STILL in the wrong place and can cause bump steer.
Bottom line is that if there were an easy spindle swap like this, it would have been public knowledge 20 years ago.
Old October 13th, 2014, 10:58 AM
64Rocket's Avatar
What happen with Scarebird, they make the brkts and a list of parts you need to finish. You still your spindle and I believe the speedo cable is driven by the dust cap on the rotor. Seams like an easy job to me.
Gene
64Rocket is offline
Old October 13th, 2014, 05:56 PM
67 heavy metal
Gene
yes it is a fairly easy job just need to get the kit and parts. I have to budget since I have three to do. I should get the kit and later buy the rest of the parts.
Old October 13th, 2014, 07:52 PM
KDV
KDV's Avatar
My factory original manual 4 drum setup took a 1/4 mile to grind to a stop.
I thought about converting to front disc but heard my 14x7 rims wouldn't clear the caliper.
So I opted for only a manual to power drum conversion - improved my stopping ability tremendously!!
I'm completely comfortable driving in traffic now
KDV is offline
Old October 14th, 2014, 07:03 AM
And yet, 14x7 wheels came on disk brake cars from the factory...
Old October 14th, 2014, 07:53 AM
Joe, will 72 disc brakes, spindles and all, go without problem on a 67 drum car? Olds Cutlass on both cars.
Edit: I mean, regarding this ball joint angle.
Koda is online now
Old October 14th, 2014, 07:58 AM
Yes. All 1964-72 A-body spindles interchange (and are the same as 67-69 F-body and 68-74 X-body). There are some differences in the size of the bolts that hold the steering arms, but if you swap the entire assembly there are no issues. And the 1968-earlier cars will likely have the drum brake-only wheels if they are original.
Old October 14th, 2014, 09:06 AM
Thanks. I've got a set of the 69 SSIs that work with disc brakes, so I should be good on that end.
Koda is online now
Old February 8th, 2018, 07:34 AM
Schnets's Avatar
SSII's and disc brakes
Hello all,
Reading old posts on converting drum to disc, I've read some information indicating a 10" disc was used on the 64-72 A body style cars, so my question is will the 11" single piston disc brake systems available on the internet; speedway.com; fit under the 14X7 SSII's?
thanks
Schnets is offline
Old February 8th, 2018, 07:41 AM
Originally Posted by Schnets
Hello all,
thanks
Sorry, but you didn't read that here, and it is flat wrong. First, disc brakes were only factory installed on 1967-up A-body cars (however the factory parts will fit back to 1964). Second, every single one of these A-body cars with disc brakes got 10.75" diameter rotors. This is often rounded up to 11", but the actual dimension is 10.75". There was NEVER a 10" rotor used on these cars from the factory. There ARE aftermarket kits that claim to fit the drum-only 14" wheels used on the 1960s cars. These kits do use 10" rotors and tiny calipers. I fail to see why anyone would waste the money and time, as braking force with them isn't appreciably better than the stock drums.
The 1967-68 cars used the fixed four=piston calipers. The 1969-77 cars used the sliding single piston calipers with 2.75" pistons. The 1978-88 cars use the sliding single piston metric calipers with 2.375" pistons. Every single SSII/III wheel every made by the factory will clear any of these factory disc brake setups, despite what some aftermarket companies may try to tell you.
Old February 8th, 2018, 08:28 AM
Schnets's Avatar
Thanks Joe for the clarification. Braking force is what it's all about. My 1970 Oldsmobile Chassis service manual does state the A body F-85 caliper OD is 1" x 11.3" with a single piston caliper. I have 11-3/4" clearance on the inside of my 14X7 SSII's, so if the aftermarket 11" (actually 10.75") disc's will work, I'd prefer to go with all new vs. old from a junk yard. New spindles as well of course.
Schnets is offline
Old February 8th, 2018, 08:52 AM
1of1442's Avatar
X2. The other cars on the road and their ability to stop much quicker was the deciding factor for me.
1of1442 is offline
Old February 8th, 2018, 09:51 AM
Something you should consider is that new does not always mean better. A spindle is a chunk of machined metal. Properly cared for, it can last 200 years. OEM spindles were made of better steel than most new ones (which come from China.) We here typically regard old US steel as better than new Chineseium, which was a term used much by, and possibly coined by, one of our dearly missed departed friends, to depict his scorn at the inferior Asian metallurgy. Now, new stuff made in America of good material may well be better, but then you are getting into "back-engineering" vs original drawings, which is a whole other story.
Koda is online now
Old January 2nd, 2019, 03:08 PM
'67 Delmont Convertible
imcgm's Avatar
man, this thread is confusing. i have a 67 delmont id love to convert to disc but it would appear it is not possible. would everyone agree that is the end result of this thread? (except of course some EXTREMELY rare car(s) that no one will ever find and that no aftermarket parts are produced because they were so rare)
i should simply stop entertaining the idea...does that sum it up?
Mike
imcgm is offline
Old January 2nd, 2019, 03:19 PM
  #31
Mike
Uh, no, not everyone would agree. First, the full size disc brake setups are not that rare. FYI, every single full size Olds built in the 1970 model year came with power disc brakes as standard equipment. That's about 280,000 cars in that model year alone and those brakes do fit your 67. Yes, you will need different wheels. Yes, new rotors are very difficult to find, however it is not difficult to modify the rotors from a 2003-2007 Cadillac CTS with base suspension and brakes to fit - basically you need to have the center bore opened up and the lug bolt pattern redrilled for the 5 x 5" pattern. That rotor is the same 12" diameter and 1.25" thickness as original. The calipers and hoses are readily available.
Old January 2nd, 2019, 03:38 PM
  #32
bw1339's Avatar
I'm in the process of converting my '66 Toronado to disk brakes. I hate being surrounded by vehicles with much shorter stopping distances.
bw1339 is online now
Old January 2nd, 2019, 03:55 PM
  #33
imcgm's Avatar
Joe, THANKS for giving me some hope...lol.
i dont want to be a pest but from what i think you are saying i could basically get the calipers, pads, hoses, bearings, wheel seals from something like a 442 or an 88 and do your rotor trick and im basically good?
id be pretty excited if i have this figured out (thanks to all of you)...haha
Mike
imcgm is offline
Old January 2nd, 2019, 03:58 PM
  #34
Mike
Read it again. The spindles need to come from a FULL SIZE Olds only. The 442 is a Cutlass. Full size is Eighty Eight or Ninety Eight. I strongly suggest using the 1969-70 style brakes with the single piston floating calipers. This is what I am putting on my 67 Delta.
Old January 2nd, 2019, 04:18 PM
  #35
imcgm's Avatar
88 or 98...check. i think i got it ))
thanks again!
imcgm is offline
Old January 2nd, 2019, 11:16 PM
  #36
eric66's Avatar
I will get a set at work .Joe do you have the measurements for the center hole and bolt pattern?
eric66 is offline
Old January 3rd, 2019, 07:22 AM
  #37
The bolt pattern is 5 x 5". I'll get the center bore diameter this weekend.
Old January 3rd, 2019, 07:32 AM
  #38
imcgm's Avatar
awesome, that will save me some time also. ur the best joe!
imcgm is offline
Old January 3rd, 2019, 06:18 PM
  #39
eric66's Avatar
You the man ,Joe
eric66 is offline
Old January 5th, 2019, 12:36 PM
  #40
eric66's Avatar
This what i found Joe.
eric66 is offline
Quick Reply: To disk brake or not to disk brake that is the question
