fuel mileage for 455
Old November 11th, 2014, 04:56 PM
Kyle's 77 Cutlass's Avatar
Hey guys, whats the guesstimate of fuel mileage for a 72 455 with Ga heads running 3:73?
Kyle's 77 Cutlass is offline
Old November 11th, 2014, 05:04 PM
Jerry the wrench's Avatar
12.....what do I get if I win?
Jerry the wrench is offline
Old November 11th, 2014, 05:31 PM
oldspackrat's Avatar
I'd guess maybe 10?
oldspackrat is offline
Old November 11th, 2014, 05:37 PM
Okay, just wondering. Thinking of swapping my 350 in tnx and transplanting a 455
Old November 11th, 2014, 05:46 PM
Around town 6-10... the fun factor is priceless.
oldcutlass is online now
Old November 11th, 2014, 05:51 PM
DLaz70OLDS98's Avatar
If your concerned about mpg than you shouldn't be thinking about a 455.
DLaz70OLDS98 is offline
Old November 11th, 2014, 06:52 PM
Bfg
Bfg's Avatar
Back in the day $2.00 worth of Ethel would let you cruise all night long!
Bfg is online now
Old November 11th, 2014, 07:11 PM
Justin
oldstata's Avatar
X2
8 hwy and 2 around corners is my guess
oldstata is offline
Old November 11th, 2014, 07:20 PM
My 350 is making 10 now. So a 455 with more torque and hp, priceless.
Old November 11th, 2014, 07:41 PM
dc2x4drvr's Avatar
dc2x4drvr is offline
Old November 11th, 2014, 07:58 PM
steverw's Avatar
Depends on how you drive it, anywhere from 7 mpg if your trying to conserve to 7 blocks pg if your havin fun with it.
Steve
steverw is offline
Old November 11th, 2014, 08:08 PM
hullinger's Avatar
My '73 Custom Cruiser with 2.93 rear gearing consistently gave me 11 MPG of spirited around town driving. I did get 14 MPG once when I burnt half a tank on the highway running consistently at around 70 MPH. I will say however that 11 MPG was a welcome improvement over 7 MPG, which is what I was getting before leaning out the carb.
It's amazing what the different metering rods will do for your mileage.
Chris
hullinger is offline
Old November 11th, 2014, 08:15 PM
My 350 makes about 14-16 on the highway pushing a fullsize Delta that's crossed the scales at the local quarry at over 5,000 pounds, through a 3:08 rear and TH400.
You must be having a LOT of fun to get 10 out of a cutlass.
MDchanic is offline
Old November 12th, 2014, 12:02 AM
Vandy's Avatar
if your getting more than 3 gallons per mile your doing it wrong.
I think mine got 6ish?
Vandy is offline
Old November 12th, 2014, 01:10 AM
nsnarsk65cutlass's Avatar
5 at best
nsnarsk65cutlass is offline
Old November 12th, 2014, 04:32 AM
Okay thanks for the input guys
Old November 12th, 2014, 05:26 AM
Mr. Johnson
rjohnson442's Avatar
I average 6-7mpg in my 72 (461 with a 850cfm carb) No vac advance and 2.7 gears car weight is 3720 with me in it and half a tank of gas. I get the best milage out of her @ speeds around 40-50 mph. Now if I stomp on the gas and do a nice pull just once that all goes out the window and drops me down to around 5 mpg, which usually has to happen a few times when I'm in the car
rjohnson442 is offline
Old November 12th, 2014, 05:58 AM
Oldzee's Avatar
Man I gotta tell ya, I'm glad to read what everybody's getting for mileage. I'm new to this as I just got my '72 Hurst back in June and so far I've put about 170 miles on it. Used 2 tanks of gas to do it. Based on the 15 gallons I seem to put in each time, I figure the tank must be around 16 gallons or so? (The tank's never completely empty when I gas up). I figure I'm getting around 6 miles to the gallon with my open 3.23 rear (and open wallet). Love it!
Oldzee is offline
Old November 12th, 2014, 06:13 AM
twintracks's Avatar
I averaged 18 mpg over 4,100 miles in the 2013 Great Race. Half of which was highway miles going to the start, and returning home from the finish.
'68 Toronado, stock 455 except for a Pertronics II ignition.
twintracks is offline
Old November 12th, 2014, 06:22 AM
brown7373's Avatar
As steverw said, it's according to how you drive it. My Olds is a 350, but I also have a 1970 Bonneville convertible 455 with a 2.93 rear. It's been off the road for a few years, but I came across a little book recording fuel mileage over a couple years. It showed mostly 13-14. Some of it down in the 11s, but some highway 15 to 16.
I know it is a heavy Pontiac with a much higher rear gear, but not much different than an Olds. Most of my cruising is done on cruise control, which helps the mileage.
Back in 1979-80 on a trip from Florida to North Carolina for Thanksgiving I got over 20mpg. Cool weather, no A/C running and the availability of leaded high octane fuel sure helped!
brown7373 is offline
Old November 12th, 2014, 07:20 AM
oldsmobiledave's Avatar
Fyi
I have a 0.060" over 455 in my 1980 GMC p/u. With T400, 3.73 gears & a 29" tall 235 75 15 tall tire on the truck I get 11 mpg cruising @ 65 mph. That is 11 miles per imperial gallon or 9.3 miles per US gallon. My truck weighs 5000 lbs.
oldsmobiledave is offline
Old November 12th, 2014, 02:50 PM
BlackGold's Avatar
Man, I can't believe how low some of you guy's mileage is. My '70 W-30 with 3.90 gears gets 10 mpg, whether city or highway driving. And it runs rich. Not that 10's great, but it sure beats 6 - 8.
BlackGold is offline
Old November 12th, 2014, 03:10 PM
Hookers under Hood
76olds's Avatar
I'd just drive er' and let the wife take it out when its close to E !!! Let her fill it up . Put-r-ther!!
76olds is offline
Old November 12th, 2014, 04:01 PM
Lots of input here. Wow
Old November 12th, 2014, 04:02 PM
How much is it a hassle to transplant a 455 into a tnx?
Old November 12th, 2014, 04:04 PM
Gmc
Old November 12th, 2014, 04:08 PM
Fyi
It was a 5.7 diesel new so it was a breeze.
Old November 12th, 2014, 04:36 PM
Gary M's Avatar
Daily driver?
Mines not for daily so I don't care what I get. Is yours for everyday use?
Gary M is offline
Old November 12th, 2014, 05:18 PM
Ya that would make it simple.
Yes it is my truck I use spring to fall.
Old November 12th, 2014, 05:27 PM
Gary M's Avatar
Then I would find another 350 unless you are hauling massive weight. 350 has good HP and mpg. We need more info on this issue to help you further.
Gary M is offline
Old November 13th, 2014, 11:59 AM
  #31
Originally Posted by Oldzee
'72 Hurst ...
... I figure the tank must be around 16 gallons or so?
A '72 should have a 20 gallon tank.
I mapped mine out back in the 80s and it's 15 gallons from F to E and 2.5 gallons from E to sitting on the side of the road.
Fun71 is offline
Old November 13th, 2014, 04:35 PM
  #32
I guess you found that out the same way as the rest of us after saying "it's got plenty of gas left at E".
Old November 13th, 2014, 04:46 PM
  #33
Oldzee's Avatar
"A '72 should have a 20 gallon tank.
I mapped mine out back in the 80s and it's 15 gallons from F to E and 2.5 gallons from E to sitting on the side of the road."
Thanks for that info. I take it you weren't in a '72 at the time?
Oldzee is offline
Old November 13th, 2014, 11:03 PM
  #34
'70 Supreme.
Fun71 is offline
Old November 14th, 2014, 12:11 AM
  #35
Magna86's Avatar
My 71 was getting 13-14 city and 19-20 on the highway cruising at 60 with the 2.56 rear. Haven't driven it very far with the 3.08's since tires need replaced due to age and its sitting in storage.
Magna86 is online now
Old November 14th, 2014, 02:34 AM
  #36
jensenracing77's Avatar
I was getting 15 in a 76 98 with a stock 455. How many of you are going by your odometer? That is not very accurate because most of them do not read correct anymore. Take a 10 mile stretch of highway and check it against the mile markers, You will find them off.
jensenracing77 is offline
Old November 14th, 2014, 04:15 AM
  #37
I pull my 7000 lb camper back and forth to work. When I do this, mileage drops to 5
Old November 14th, 2014, 08:40 PM
  #38
I had a speedo calibration box made for mine after switching out the 2.56 rear so it was just as accurate as when it left the factory. I guess that's just one more thing on my car that is not "factory original".
Fun71 is offline
Wood
January 18th, 2015 09:23 AM
toms vista
August 26th, 2013 08:09 PM
Danp76
February 26th, 2013 02:01 PM
1956OldsDarrin
February 20th, 2011 06:38 AM
Scottem
June 22nd, 2009 01:48 PM
Quick Reply: fuel mileage for 455
