Fuel sending unit tool J-36608
I was going to tackle replacing the fuel sending unit, along with the fuel and vent hoses this fall on my '72 98.
Does anybody have this J-36608 tool?
I know I can use a hammer and chisel or screwdriver...but this tool looks like it would make the job quicker and easier.
Also, should I worry about flushing out the gas tank or just temporarily put an in-line filter for a few months? What would be the appropriate finish for the tank...just paint it with Rustolium or leave it as-is?
Does anyone have any other tips on dropping the tank?
Thanks,
Dan
Thanks,
Dan
I replaced the sending unit without that tool. It was very easy to do. If you're not going to replace the tank then see how dirty or rusted it is once the unit is off. Actually if there is rust in there I would replace it.
Dropping the tank is also extremely easy - BUT - make sure u have very little fuel in there. Aside from the weight (each gallow is about 6.5 lb.) you don't want to get splashed through a vent or the filler.
Eastwood sells some nice tank paints that look like tank metal and also clear coats if the tank is basically in good shape.
While you have it out, put in a new sending unit. They're available for your car at rockauto.com.
reach in there with your hand (I could fit my arm up to my elbow into the opening of the tank on my '67 Delta)
Good thing you are not a Proctologist by trade!
Maybe if I wait until the tank is dry, I can use a shop vac to get out the "crud"...
How the hell can u get ur arm in there............are u a skinny girl. I could hardly get 2 fingers in the holes and I am far from fat or super muscular. A brand new tank is probably about $175 to $225...OK not super cheap, but if it won't break the bank that is the best and easiest path to take.
I got under the car last night and sprayed the bolts with LiquidWrench. I thought I would spray it a few times before dropping the tank just to make the job easier.
The tank looks very clean on the outside and the bolts did not look all that bad - so I am hoping it is clean on the inside.
The way the tank straps are, I cannot just drop the tank straight down (unless I can jack the car up 3 feet off the ground). The tank has to be dropped at an angle. I was thinking that when I take the vent hoses off the metal lines, I might be able to wedge a golf tee or some dowel rod in the hose to plug it up and keep gas from pouring out the hoses when dropping the tank.
How long are the wires on the sending unit? Should I try to disconnect them before dropping the tank...or is there enough slack that I can do it with the tank dropped?
New tanks are not necessarily available for the big cars. They're not available for my '67 Delta.
Below are two photos of the tank I took when I had it out of the car. Note the two wires (black going forward, light brown rearward). I think your car's sending unit/pick-up will have two lines as one is a vent line that wasn't present on the '67's unless the car had air-conditioning.
Note in the second photo the rubber cover over the connector for the light-brown wire. That's what you don't want to rip out when you drop the tank, so disconnect it at the other end (you can see the plastic connector at the other end in the first photo).
personally I would not recommend the shop vac unless you plan on flushing the tank and then letting it sit for a week or so with the sender out. gas fumes are far more explosive than the gas itself and shop vacs do not have sealed motors. it does not take much to cause a nasty boom. I had a friend blow up an old boat tank while cutting out the floor. he just nicked the aluminum tank but something was enough to light the old fumes. he only lived a few days after the explosion. point is be VERY cautious working around gas fumes.
Absolutely a Shop Vac could be deadly. When I took out my old tank it had less then a cup of liquid fuel in it. I left the tank in the sun for a few hours to evaporate the liquid (I was going to dispose of tank). After about 5 hours in the summer sun the liquid was gone....however it took weeks of sitting outside before the smell of gas (i.e. fumes) were undetectable.
68RocketAction
December 18th, 2014 11:19 AM
Oldskool84
October 10th, 2014 06:21 AM
