gear
Old November 4th, 2013, 08:09 AM
quentinnw2's Avatar
gear
whats a good highway gear i have a 3.42 now but my rpm is too high 60 I'm hitting 3000 with a TH350 i know it would be cheaper to change the gear than to put in a overdrive tranny.
quentinnw2 is offline
Old November 4th, 2013, 08:16 AM
3:08 would bring it down a few hundred.
oldcutlass is offline
Old November 4th, 2013, 08:18 AM
Chevy budget Olds powered
coppercutlass's Avatar
If that 3.42 is good and you do swap I'll buy the gear set
coppercutlass is offline
Old November 4th, 2013, 08:30 AM
Check the calibration of your tach. To hit 3000 RPM in third (which is 1:1), you'd have to be running tires that were about 24.5" in diameter. This would be a 225/60-14, for example. For a reasonable size tire in the 26-27" diameter range, your 60 MPH revs should be 2500 or so.
Once again, I'll strongly recommend a 200-4R over changing the rear end gears. Going to 3.08s will drop your first gear effective ratio from 8.62:1 to 7.76:1. The 200-4R gives you an effective 9.37:1 off the line and 2.33:1 in OD.
joe_padavano is offline
Old November 4th, 2013, 02:54 PM
quentinnw2's Avatar
Think I'm going to try that 700r4
Old November 4th, 2013, 02:55 PM
quentinnw2's Avatar
I'm running a 295-35-18 in the rear
Old November 4th, 2013, 02:57 PM
quentinnw2's Avatar
I'm thinking my tranny is not going in to third gear now I'm thinking about it .
Old November 4th, 2013, 03:36 PM
car guy
gearheads78's Avatar
Your tire is pretty short. 25.9" advertised so with weight on it you are really short. Can yo not run a 40 or possible 45 series tire?
gearheads78 is offline
Old November 4th, 2013, 05:54 PM
quentinnw2's Avatar
I just bought those tires......
drjr56
September 9th, 2012 08:05 PM
Chuck C
Drivetrain/Differentials
September 5th, 2007 02:35 PM
69olds350
November 9th, 2006 07:32 AM
mainedogg72
May 24th, 2006 10:13 PM
70Supreme
August 19th, 2003 04:24 AM
Quick Reply: gear
