How do I change Transmission Modulator??
Old September 9th, 2012, 10:51 AM
MaxDog's Avatar
Hi Guys,
Can anyone tell me how I change the trasmission modulator? Its a 72 442 with a 350/350. I think I found the modulator, near the tail end of the transmission, sort-of on the top, on the passenger side.
I can't figure out how to get the dang thing off though. Do I need to move the cross-member? How is the modulator attached to the transmission, I can't see any bolts or anything.
Any help would be very much appreciated. The more details, the better. Thanks!!!!
MaxDog is offline
Old September 9th, 2012, 01:51 PM
Originally Posted by MaxDog
Hi Guys,
There's a small flat clamp that holds the modulator to the trans case. One bolt retains the clamp. Just remove the bolt and clamp and pull the modulator straight out. It will likely be difficult to pull out because the o-ring seal gets hard over time. Also, have a drip pan ready to catch any trans fluid that comes out. Slide the new modulator in (after lubing the o-ring with trans fluid, reinstall the clamp, tighten the bolt, connect vacuum line.
joe_padavano is offline
Old September 11th, 2012, 07:39 PM
MaxDog's Avatar
Do I need to move the cross-member? Thanks.
MaxDog is offline
Old September 19th, 2012, 11:06 PM
ah64pilot's Avatar
You do not have to remove the cross member to remove the vacuum modulator. Check out the attached picture to make sure you are removing the correct part.
ah64pilot is offline
Old September 21st, 2012, 09:45 AM
Registered car nut
nonhog's Avatar
FYI try and get a new hose with the new modulator.
Really hard to find that formed hose local. At least for me it was.
Boy the modulator in that picture is huge!
nonhog is offline
Tom442
July 17th, 2013 05:01 PM
dre
Drivetrain/Differentials
August 31st, 2011 11:04 AM
joe_padavano
Tech Editor's Desk
June 18th, 2008 07:11 PM
palmers65
March 29th, 2008 02:32 PM
Quick Reply: How do I change Transmission Modulator??
