Just a friendly safety tip...
Old July 14th, 2009, 11:01 PM
Registered Lunatic
Crazy88's Avatar
I'm sure most of you are aware of this, but I found something mildly disturbing under my car today, and reminders are always good...
Whenever you aquire an old car that hasn't been on the road for a while, or questionabley maintained...CHECK EVERYTHING!
While under my 88 changing the oil filter I noticed that one of the lower suspension nuts was VERY loose...like almost off the bolt. Upon checking the rest, almost all of them were loose. So yeah...I think I'll be inspecting the entire thing now.
Good luck out there and be safe.
Crazy88 is offline
Old July 15th, 2009, 04:41 AM
Captain of my ship
wolfman98's Avatar
Whew
Man glad you found that in time , it could have made for a nasty response on a tight corner
wolfman98 is offline
Old July 15th, 2009, 06:51 AM
citcapp's Avatar
Glad you found it the easy way and not the hard way. Same go's for tires,hoses, and wheel bearings, all easly forgotten.
citcapp is offline
Old July 15th, 2009, 10:28 AM
71 cutlass convertible
lshlsh2's Avatar
I know a guy that has a small plane. You do a walk around every time you fly it. His small son followed him around watching him. One day he is finished getting ready to fly his son says why is the wheel wet. What do you mean? he walks over checks it out finds a split brake line. He got so used to doing and not seeing. sometime you need another set of eyes.
Larry
lshlsh2 is offline
Old July 15th, 2009, 04:25 PM
Registered Lunatic
Crazy88's Avatar
Ya, I was lucky...check, check, recheck... get someone else to check...hah.
Crazy88 is offline
Old July 15th, 2009, 05:39 PM
csstrux's Avatar
Larry
Same with tractor trailers. And yes, you do get too used to seeing...but not seeing. Always good to do a periodical, Thorough inspection. A check list helps also.
csstrux is offline
dlmsavings1
September 3rd, 2013 09:01 AM
Joffroi
January 25th, 2011 09:53 AM
gearheads78
February 14th, 2009 10:06 AM
Dapapadon
February 2nd, 2009 11:31 AM
csouth
December 15th, 2008 04:07 AM
Quick Reply: Just a friendly safety tip...
