Need advice, how to remove crank pulleys on 1955 324 & 1962 394
Old August 21st, 2015, 07:56 PM
2blu442's Avatar
Hi All
I've got a couple core engines I'm wanting to break down and have checked. But I don't have a Chassis Service Manual for these vintages. I know the late 1960's I remove the pulleys then use a puller on the balancer. But I don't see any way to put a puller on these except on the outside of the pulleys. Don't want to screw things up so I'm needing some directions from you guys familiar with these engines.
John
2blu442 is offline
Old August 21st, 2015, 08:39 PM
Proud Viet Nam Veteran
redoldsman's Avatar
John:
The most difficult part is breaking the bolt loose that holds the balancer on. One you have that out the balancer comes off pretty easy. It is not pressed on. I am sure these have been on there for years so you may have to tap on them a little but they should come off pretty easy. Good luck.
redoldsman is offline
Old August 22nd, 2015, 06:30 AM
2blu442's Avatar
Thank you for the instructions, I've been soaking the 324 with Kroil but its still on there pretty tight. I'll keep working on it!
John
2blu442 is offline
bob p
April 10th, 2015 01:55 PM
wr1970
March 29th, 2015 05:36 AM
2blu442
February 11th, 2015 02:03 PM
Dave Siltman
July 24th, 2014 02:55 AM
Bikes&Rods
May 7th, 2012 08:17 PM
Quick Reply: Need advice, how to remove crank pulleys on 1955 324 & 1962 394
