New Rubber Brake Pedal
I know this is probably a dumb a$$ question but here goes....I finished the restoration on my Cutlass. I ordered a new rubber brake pedal, and it came in today. How do these go on? I also have one for the emergency brake pedal, and for the life of me I cannot get it to fit. Any help or suggestions would really be appreciated. Thanks
Thanks Oldsguy. Thats where the problem is coming in. On the back of the rubber pedal part the rubber wraps around. I know it is supposed to overlap to fit over the pedal, but I can't get it more than half on?
My brake and clutch pedal pads just slipped on as Oldsguy said. The gas pedal has to sort of snap or clip on to stay and move freely with that pedal. The e-brake also slips on, but I had to use a little contact cement on it, because it kept coming off.
You might try heating it up a "little bit" w/a heat gun or blow dryer to make the rubber more plyable. I remember it being hard to get on, then not staying on until some type of glue put there to hold it.
You may not be able to slip the lip over, with just your fingers. A small putty knife will help ease it on. The new ones are a little stiff compared to the old one.Be carefull when you come to the ends, as you can rip the lip, then it won't stay on.
If something is to tight I always use a little lube...
A little dish soap and a puddy knife on a warm pad (Hot water works but don't burn yourself) should be the best of all install techniques.
New ones are very stiff.
Guess I was a little late.
Brian
Brian
