Odd brake master cylinder
Old May 25th, 2010, 05:26 AM
"me somebody" site member
aliensatemybuick's Avatar
I noted the brake master cylinder in a '67 Toro currently offered on EBay has an odd master cylinder with a "bolt-on" cap:
I have seen similar jobs offered for sale, for example, this one:
http://cgi.ebay.com/ebaymotors/67-72...Q5fAccessories
As far as I can deternmine from other examples I've seen in person, there is no provision for a bail for the typical cap you see on these era cars. Seems to me that a bolt-on cap would discourage regular check of the fluid level.
Anyway, does anyone know if these were some kind of aftermarket parts? offered "back in the day"?
aliensatemybuick is offline
Old May 25th, 2010, 07:27 AM
Cutlass Lover
cutlassgal's Avatar
Well, The Prettiest One has one of those bolt on type caps also!! I don't know why. Don't know if you can see real well in this pic....
cutlassgal is offline
Old May 25th, 2010, 07:35 AM
Interesting, thanks.
OK, here's where I suppose I should admit that the reason I'm so curious is that the '67 442 I bought recently has one as well.
Old May 25th, 2010, 08:28 AM
The M/C with bolt-on cover is simply an aftermarket replacement. It is functionally correct, but obviously not appearance correct. Nothing special, just a replacement part for a normal wear item.
joe_padavano is offline
Old May 25th, 2010, 10:02 AM
It is as I suspected then...thanks for the confirmation.
The radiator in my car is also an incorrect replacement part. Of course, I told my wife when I bought THIS car that I would not worry about such underhood details, i.e. when it comes to those "wear items".
On the topic of underhood details, I figure now is as good a time as any to mention a possible interchange when it comes to the air cleaner on a 4 speed '66-'67 442...seems a similar era Chevy unit is VERY close, with the exception of an air tube on the bottom that can be easily removed (and the hole plugged).
http://cgi.ebay.com/ebaymotors/ws/eB...m=130391596935
Or maybe this is old news...
veltboy618
Brakes/Hydraulic Systems
July 14th, 2011 07:10 PM
trademen
November 17th, 2010 09:57 PM
trademen
October 4th, 2010 12:28 PM
<marksz71>
October 20th, 2006 07:14 PM
Quick Reply: Odd brake master cylinder
