Removing tar & oil splatter
Old July 1st, 2013, 03:19 PM
oldsmobiledave's Avatar
Drove home from an oil well yesterday. Highway crews were applying hot tar as a crack sealant on one of the secondary highways that I travelled & I managed to cover most of my work truck in tar splatter.
A pressure wash would not touch this stuff but it took of all the mud from the rig roads. In my efforts to clean the tar from the truck I found something that works really well. Spray WD-40 (fish oil) on a Mr Clean Magic Eraser & rub in circular motion. A light mist of WD-40 on the really heavy spatter sections & let it penetrate for a moment really helped too. Rinse with water & wipe dry. Had the entire truck clean in an hour. Works like a charm. Give it a try if you get tar, ashphalt, oil or even poplar tree sap on your ride.
Time for a beer! ...maybe two!
oldsmobiledave is offline
Old July 1st, 2013, 03:33 PM
jfb
jfb's Avatar
single stage paint use enamel reducer,lacquer also. base clear lacquer thinner on a rag and use gloves it can soak into your wrists easily and it stinks use caution like outdoors.
jfb is offline
Old July 1st, 2013, 03:38 PM
more
I was working out doors with gloves. I was amazed at how easily it came off. A rag & the WD-40 did not work nearly as well as that Magic eraser with WD. Those things are awesome for cleaning stuff & taking off marks on walls etc.
Old July 1st, 2013, 08:10 PM
Oldsdruid
rocketraider's Avatar
WD40 can clean other things besides tar. I've used it to clean and dress grungy spark plug wires where I figured lacquer thinner or other strong solvent would have taken off the printing.
If all there is on wiring is grunge, WD40 works for that too. I was never that lucky. Someone had always done a quickie engine detail with a black spray bomb before I got there. So out came the lacquer thinner.
PreKleano or Duracryl works good to clean off grunge too.
rocketraider is offline
Old July 1st, 2013, 09:55 PM
Bug & Tar remover, in the aisle where they have the wax.
1969w3155 is online now
Old July 2nd, 2013, 06:17 AM
fyi
Been there done that. The WD-40 & magic eraser works 10X faster.
Old July 3rd, 2013, 07:42 PM
Ed Carpenter's Avatar
Gasoline on a soft cloth. Dissolves tar quickly.
Ed Carpenter is offline
pureplaya442
May 3rd, 2019 02:50 PM
W-27
April 9th, 2015 06:02 PM
jensenracing77
January 25th, 2014 06:55 AM
cobalt
February 8th, 2013 06:05 PM
Steve Wike
June 26th, 2010 07:21 AM
Quick Reply: Removing tar & oil splatter
