Speedometer gear for 3.42 rearend
Old July 22nd, 2012, 08:28 AM
IYAOYAS
1969oldsH's Avatar
I am having troubles finding a speedometer gear for my TH-350 Trans. Currently reading 75-80 when im going 60-65.
Anyone know of a site with data to find the correct part?
1969oldsH is offline
Old July 22nd, 2012, 08:50 AM
71 & 72,now I want a 68
w-30dreamin's Avatar
Good question,I'll be changing my rear gear soon. Same combo,th350 with 3:42 gears.
I'll be watching your thread for info.
w-30dreamin is offline
Old July 22nd, 2012, 09:46 AM
"Car"mudgeon
GAOldsman's Avatar
I think this may shed a little light on the subject
GAOldsman is offline
Old July 22nd, 2012, 09:47 AM
stevengerard's Avatar
there is a guy on ebay from Southwest Michigan that sells the correct driven gears and speedo gears, he can tell you what you need. There is a site though I'll try to find it'
stevengerard is offline
Old July 22nd, 2012, 09:57 AM
DeltaPace77's Avatar
Another place to try is transmissioncenter.org, as they sell just about any GM tranny gears.
DeltaPace77 is offline
Old July 22nd, 2012, 10:03 AM
IYAOYAS
1969oldsH's Avatar
thank you all for the help on this. i have to figure out what my drive gear is right now and figure it out. thanks answered all of my questions.
Old July 22nd, 2012, 11:38 AM
Finding out the speedo drive gear size, should be easy as pulling out the driven gear housing, and checking gear color. Really depends on what axle you originally had vs the 3.42 now, as may need a new driven gear plug in housing as well. The Transmission Center site shows all of this. Note, the listed 700R4 parts are the same for non Chevy TH350's. I went from 2.41 axle on my car to 3.73's and had to change both gears when running a TH350. You'll need to pull the driveshaft, and unbolt the tailshaft housing to change the drive gear. When I switched to a 700R4, all gears were directly swapable. The 700R4 I used, had a Chevy bolt pattern, and needed an adapter plate to make it work.
Old July 24th, 2012, 12:18 PM
Slomega's Avatar
Thanks for the link (www.73-87.com) ...
VERY GOOD Site for references, especially with the Speedo Gear calculations and ratios!! ....
Transmissioncenter.org mentioned above was helpful too!
Slomega is offline
Old July 24th, 2012, 12:31 PM
"Car"mudgeon
GAOldsman's Avatar
No problem Dave, always my pleasure to help out.
Scot
Old July 24th, 2012, 01:47 PM
ah64pilot's Avatar
Best place I've dealt with is Performance Automatic Transmission Center (PATC). They have everything for the speedometer gear, housings included.
http://www.transmissioncenter.net/sp...n_______va.htm
ah64pilot is offline
Old July 24th, 2012, 03:33 PM
hookem horns's Avatar
I faced this same issue a year ago. Got an adaptor so I did not have to change both drive and driven gears. Within a couple of MPH on the GPS now.
https://classicoldsmobile.com/forums...o-adapter.html
hookem horns is offline
Old April 9th, 2018, 12:36 PM
brownbomber77's Avatar
Old thread, yes. I'm trying to find if I can just stick a 43 tooth speedometer gear into the 18 tooth drive gear to make it read right with a 3.42 rear from 2.73. This is a '77 TH350.
brownbomber77 is offline
Old April 9th, 2018, 12:55 PM
Try here: http://www.speedometersolutions.com/
1969w3155 is offline
Old April 9th, 2018, 01:08 PM
Ah, there's a link I haven't seen yet. I visited most of the other sites other suggested on different forums. The TCI website and a couple others that sell trans parts. I'll give them a whirl. Thanks
Old April 9th, 2018, 07:55 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Supposedly there are 3 different housings, you need the correct one for the 43 tooth gear.
olds 307 and 403 is online now
oldgeardad
October 27th, 2013 10:37 PM
1951Super
Drivetrain/Differentials
April 12th, 2012 05:33 AM
ELECMAN
October 12th, 2010 01:47 PM
delta881972
February 26th, 2010 09:42 AM
jensenracing77
February 7th, 2010 05:51 PM
Quick Reply: Speedometer gear for 3.42 rearend
