Temp Sensor? Temp Sending Unit? Help!
I have a 54 oldsmobile and need to fix the temperature gauge. The mechanic is asking me to find a temperature sensor for the temp gauge. Is the sensor the same as a temp sending unit? Thanks for your help!
Sensors and/or senders put out a variable signal to operate a gauge, as opposed to a switch that opens/closes at a certain temp/pressure/etc to turn on a warning light. So yes, sensor/sender are different names for the same thing.
68RocketAction
December 18th, 2014 11:19 AM
costpenn
November 7th, 2013 09:29 AM
