venting the gas tank
Old April 17th, 2013, 03:51 AM
1954Bob's Avatar
Question venting the gas tank
Anyone know anything about venting the gas tank on a 1967 442. The car when we broke it down for resto had 2 lines coming off the tank and one had a hose with a old spark plug shoved in it. Anyone know the correct way to vent it and parts needed to do that job.
Thank you , Bob
1954Bob is offline
Old April 17th, 2013, 06:36 AM
There are a couple of kits that work, basically 2 rubber lines and a plastic filter stufffed with cotton. It clamps in behind the bumper above the license plate.
Just scroll down until you see it:
http://www.inlinetube.com/New%20Prod...Oldsmobile.htm
oldcutlass is offline
Old April 17th, 2013, 06:59 PM
2blu442's Avatar
That will work well, but I believe the factory setup was a little different in 1967. What I've seen is a chuck of cotton like filter stuffed into the end of the large hose and a plastic plug with a small hole in the center pushed into the small hose.
I wasn't able to get the link to open, but I believe what Oldcutlass is describing was used in 1968-72 and would probably work better than the factory 1967 parts.
John
2blu442 is offline
Old April 17th, 2013, 07:17 PM
I looped my 2 lines together and don't run a vent. I get a minor pressure build not enough to affect anything on a really warm day.
19sixty5
Non-Olds Engines
February 10th, 2014 03:35 PM
ah64pilot
April 9th, 2012 02:55 PM
Texas442
January 30th, 2012 05:36 PM
one4theroad
October 10th, 2009 01:54 PM
glord
July 21st, 2009 11:23 PM
Quick Reply: venting the gas tank
