To Verify Numbers Match
Old July 21st, 2011, 01:03 PM
72old$'s Avatar
Smile To Verify Numbers Match
I would like to verify whether the engine serial number on my 72 Delta 88 matches the VIN. Where, on the engine, would I look to find the number? Thanks in advance. 72old$
72old$ is offline
Old July 21st, 2011, 01:10 PM
Tony72Cutlass'S''s Avatar
Your engine unit number is on your oil filler tube, unless someone changed in the past 40-odd years. Page 0-3 of your cutlass service manual.
-Tony
Tony72Cutlass'S' is offline
Old July 21st, 2011, 01:14 PM
Just in case, here ya go
Old July 21st, 2011, 01:41 PM
Indy_68_S's Avatar
The serial number is on the front left of the block on a little pad just below the left head's front freeze plug.
It should be something like 38M123456
The last 6 digits should match the last 6 of your VIN.
Indy_68_S is offline
Old July 21st, 2011, 03:34 PM
-Tony
The engine unit number does not match the VIN. All 1968-up Olds motors have a VIN derivative stamped on the block. The first character of the VIN derivative matches the first of the VIN and the last eight match the last eight of the VIN. The number is stamped on a pad at the left front corner of the block.
joe_padavano is offline
Old July 21st, 2011, 03:57 PM
Resident Eskie
snowballs442's Avatar
Joe--Is that true of 1969 442s as well? OK I just re-read your post and it said 68-up thanks
snowballs442 is offline
Old July 21st, 2011, 07:50 PM
Randy C.
rcorrigan5's Avatar
It's true about the VIN derivative of all '68 and newer. The pad with the VIN derivative is hard to see on an assembled engine, with the exhaust manifold and brackets in the way. But, if the pad area is clean, and you get in there with a small mirror and a flashlight, you can see it.
Randy C.
rcorrigan5 is offline
Old July 22nd, 2011, 08:28 AM
Did anyone pick up on the fact that the supposed VIN derivative in the photo I linked to above appears to have TEN characters, not nine? What's up with that?
No, it's not a photo I took, I stole it from another thread on this site.
Old July 22nd, 2011, 08:51 AM
Indy_68_S's Avatar
Odd. It looks like :
37 1Z 129581
I understand :
3 = Oldsmobile
7 = 1967...or 77..or 57,87 (?)
129581 = VIN derivative
What the heck is '1Z' ?
Super secret experimental hi-po ?
BTW..If you look closely at mine (hard to see in that pic), you'll see it was so good they stamped it twice ! Its exactly the same number....twice.
Old July 22nd, 2011, 09:05 AM
37 1Z 129581
Yeah, that's what I read also. Olds didn't stamp a VIN derivative until the 1968 model year, so if the apparent "7" is the model year, it would be 1977. I think by the 1980s GM was using letters for the year. It could also be that the "7" is spurious and the "1" is the year. In any case, whoever set up the stamp for this block apparently was not paying careful attention - proving that mistakes DID happen.
Old July 22nd, 2011, 09:11 AM
Indy_68_S's Avatar
Ahhh...So maybe it was a '71 and the stamper was a new guy who figured he better stamp 3 71 Z (Olds - 71 - Freemont) ...
...In any case, whoever set up the stamp for this block apparently was not paying careful attention - proving that mistakes DID happen.
On mine, the top stamp is pretty faint, but readable for the last couple of digits.
The stamper must've looked at it and decided to hit it again below that.
He must've hit a high nickel area at the end of the first stamp !!
Old July 22nd, 2011, 09:53 AM
svnt442's Avatar
The casting number behind the water pump will clear this one up.
svnt442 is offline
Old July 23rd, 2011, 07:32 PM
72old$'s Avatar
Smile Absolutely right!
Thanks Joe, you are 100% correct about the engine ID. number location. The number does match with the VIN and that's great! I'm curious about the "M" code in the number and what it may designate? I haven't been able to examine the block closely yet, but it appears that the block may have been painted gold. Does anyone know if the 1972 Olds Delta 88 350 block may been factory painted gold? Thanks all for your help in advance.
72old$ is offline
Old July 23rd, 2011, 07:39 PM
"Car"mudgeon
GAOldsman's Avatar
M = Lansing, Michigan as in your VIN # should be 3L67_2M546747 if its a convertible, can't tell from your avatar. The under score is the engine code letter (H,J,K,M,T,U,Vor W) ( with T,U & W designating 455 engine) and if it is a '72 350 then yes it is gold, the 455 would have been metallic blue.
GAOldsman is offline
Old July 23rd, 2011, 07:42 PM
1972 350 — Gold
1972 455 — Blue
MDchanic is offline
Old July 23rd, 2011, 07:54 PM
"Car"mudgeon
GAOldsman's Avatar
And on your engine stamp
3 = Oldsmobile
2 = 1972
M = Lansing
546747 = Production #
Old July 23rd, 2011, 08:09 PM
Indy_68_S's Avatar
3 = Oldsmobile
2 = 1972
M = Lansing
& 546747 should match the end of your VIN....
j_link
September 14th, 2013 09:12 PM
JS71SX
April 8th, 2012 05:17 AM
January 23rd, 2012 01:44 PM
Blackjack33
October 13th, 2009 12:15 PM
Deepsouthauto
March 20th, 2006 04:14 AM
Quick Reply: To Verify Numbers Match
