what do i have here
Old October 4th, 2008, 06:10 PM
shash'71cut"S"'s Avatar
Question what do i have here
well thats what it says 336871R155577
Edit by Oldsguy to fix a screw up by me:
OP originally asked if he had a Cutlass S model and listed the vin above.
Last edited by shash'71cut"S"; October 4th, 2008 at 06:35 PM. Reason: net question
shash'71cut"S" is offline
Old October 4th, 2008, 06:22 PM
Past Administrator
Oldsguy's Avatar
If it was a 3G87 for the first four digits it would be an "S". I can't decipher the number you listed though (my reference may be incomplete though). It doesn't look like the number you listed has enough letters in it. There should be a badge on the front "head knocker" of the hood of an "S", and the hood should have non-function louver plates on either side of the center line.
Oldsguy is offline
Old October 4th, 2008, 07:00 PM
Past Administrator
Oldsguy's Avatar
Sorry, I tried to merge your two threads and somehow merged it with someone else's so you original question got lost in limbo (maybe it will show up). Anyway, after fixing the other thread, I went back to this one and found your first question missing, oh well.....
The vin listed on your paperwork may very well be because motor vehicle department or whatever you call it in your state listed it that way but is sure doesn't look familiar to me. What is the vin on the car? It should be visible under the windshield on the dash in spot in front of the driver. Also, you should be able to find some information on the driver's door post (I think that's right for '71). At any rate, hang tight, someone else may chime in soon and help us out.
Oldsguy is offline
Old October 5th, 2008, 07:18 AM
3 = Oldsmobile Division
36 = Cutlass S
87 = Holiday Coupe (2dr HT)
1 = 1971 model year
R = Arlington, TX assembly plant
155577 = sequential build number
joe_padavano is offline
Joffroi
February 22nd, 2011 04:21 PM
67grandsport400
January 22nd, 2011 10:32 PM
bluechevelless
June 1st, 2010 06:06 AM
GoodOldsGuyDougie
February 20th, 2009 11:58 AM
egknz
November 21st, 2008 06:10 PM
Quick Reply: what do i have here
