Whats making this noise
Old December 11th, 2011, 03:31 PM
Railguy's Avatar
http://www.youtube.com/watch?v=7zegDQVYrao
I'd say it's a intake lobe worn off,and the exhaust valve is being sucked open.
railguy
Railguy is offline
Old December 11th, 2011, 06:41 PM
same but different
don71's Avatar
I'm not so sure thats inside the engine.
I would be looking closely at the water pump and harmonic dampner for loose pullys and checking the flexplate for loose fastners. Also, the exhaust system and its hangers... might be hitting on something.
I think this might be a good time to get out the broom handle and use it as a stethescope.
If all else fails, a compression test and a leak down test will tell you pretty quickly if your guess it correct.
don71 is online now
Old December 11th, 2011, 06:54 PM
Railguy's Avatar
I thought the noise got louder the closer the guy with the camera got to the driver side tail pipe.
railguy
Railguy is offline
Old December 12th, 2011, 06:38 AM
Run to Rund's Avatar
Take off the valve covers & check rockers and pushrods, go from there.
Run to Rund is offline
Betsyd68
July 26th, 2014 08:52 PM
68Dreams
April 26th, 2013 07:16 PM
Charles Ludwick
28
March 7th, 2012 04:45 PM
davisjd77
Alero
July 14th, 2009 04:02 AM
ls442
July 12th, 2009 01:29 PM
Quick Reply: Whats making this noise
