What's this part for?
Secondary head temperature sensor, used on '68-'70 Toros, located at spot just above trans. dipstick, light green wire with white stripe, makes a yellow light flash "STOP ENGINE."
Works completely independently of the red "HOT" light attached to the sensor in the water jacket on the intake manifold.
I never came across a diesel with one of those, but then I never saw a diesel that hadn't already been rebuilt at least once.
Seems like a Citroen way of doing something imo.
It looks to me like the bottom threads are stripped or damaged?.
Roger.
Roger.
So, I'm assuming this bolts into a dead hole on the block and it just takes temp from the block itself, or does it punch through to its own water jacket spot?
It's just one of the lower-row head bolts.
As far as I know, the idea was to read the head or block temperature as close to the combustion chamber as possible, probably because these cars did run hot sometimes, did not have a temperature gauge, and some drivers grew to ignore the HOT light.
Roger.
Dead Reckon
March 25th, 2014 01:02 PM
IZAOLDS
August 9th, 2010 08:36 AM
Texas Jim
Ninety-Eight
17
December 30th, 2009 06:28 PM
