Wheel bolt pattern for 66 delta 88
Old July 31st, 2013, 06:04 PM
bcf102's Avatar
Looking at some rims for my 66 delta 88 is it a 4.75 patten thinking some rims from a 97 camero should fit??
bcf102 is offline
Old July 31st, 2013, 06:15 PM
65B01Delta's Avatar
Your car should have a 5x5 (big) bolt pattern. Camero wheels will not fit.
65B01Delta is offline
Old July 31st, 2013, 06:20 PM
bcf102's Avatar
Ok thanks for the info,I found another pair of universal rims......hopefully these will match up!
bcf102 is offline
Old July 31st, 2013, 10:15 PM
svnt442's Avatar
If the have the long holes then no. Those will fit 5x4½ and 5x¾ bolt patterns. There were some steel wheels with dual bolt patterns made that have 5x4¾ and 5x5, but not many.
svnt442 is offline
Old August 1st, 2013, 06:09 AM
Most "universal" wheels are not. They typically only fit two of the many possible bolt patterns. As noted above, the two most common are 5 x 4.5" (Ford/Chrysler) and 5 x 4.75" (GM small). The full size cars typically used 5 x 5". This pattern is also used on many Chevy full size cars as well as some half ton pickups and vans, so wheels are readily available. Don't just look in the paper Summit catalog and think there are no wheels - they only show a fraction of their products in the paper catalogs. Look at their online site.
joe_padavano is offline
rollins
Wheels and Tires
August 11th, 2015 01:57 PM
delta88_frankfurt
April 8th, 2013 05:50 AM
1973olds98
Ninety-Eight
September 21st, 2009 05:23 PM
Nailhead 88
November 19th, 2008 08:21 AM
ss427
January 13th, 2008 08:57 AM
Quick Reply: Wheel bolt pattern for 66 delta 88
